-   -   My C-22 Project (http://www.sailnet.com/forums/gear-maintenance/83061-my-c-22-project.html)
TravelinJack 01-24-2012 04:39 PM
My C-22 Project
I picked up a project boat this past weekend after a year of planning to go down and pick it up. With work and preparing for my girlfriend to leave for Navy boot camp, I just kept putting it off. Not to mention the trailer needed a new axle and some rubber to make the journey to Austin, TX. Well she is now off in Great Lakes, IL for a few months and I have something to occupy my time while she is gone. After four hours, I finally got the axle swapped out (which I robbed from my work trailer temporarily). I do love the idea of a galvanized trailer with steel u-bolts holding it together. Then it was time to move on to the black magic that is the world of trailer lights. Another four hours, and that was finally finished. Normally these tasks would not take me this long, but I was an hour from the nearest decent sized town, and running to the hardware store was not an option. By 11:30pm it was time to hit the road. (Hopefully I'm inserting the images correctly)
[IMG]http://i98.photobucket.com/albums/l2...s/IMAG0210.jpg[/IMG]
I finally got home from what is usually less than a two hour drive in just over 3 to some very unhappy dogs. I was a little concerned about the structural integrity of the bolts and the water in the bilge so I kept it around 55 the whole way.
Here's what she looked like when I got up the next morning.
http://i98.photobucket.com/albums/l2...s/IMAG0211.jpg
http://i98.photobucket.com/albums/l2...s/IMAG0213.jpg
After pressure washing...
http://i98.photobucket.com/albums/l2...s/IMAG0218.jpg
http://i98.photobucket.com/albums/l2...s/IMAG0217.jpg
http://i98.photobucket.com/albums/l2...s/IMAG0214.jpg
Then came the task of tackling the inside after work on Monday.
http://i98.photobucket.com/albums/l2...s/IMAG0221.jpg
http://i98.photobucket.com/albums/l2...s/IMAG0219.jpg
After using a shop vac and a brush, I was able to knock the rough off it.
http://i98.photobucket.com/albums/l2...s/IMAG0227.jpg
No more standing water!
http://i98.photobucket.com/albums/l2...s/IMAG0229.jpg
So, when it stops raining I'll get back in there and continue the cleanup. I'm fortunate that I have all the main components intact, such as the mast, boom, winches etc.
With that, I do have a question for those that know. Will it cause damage if I pressure wash the inside of the boat and suck the water out as I go, or should I just go by a bunch of rags and cleaner and get after it? I don't mind the extra work as I don't want to take any steps backwards in this project. Needless to say, I'm a happy camper to finally have my own boat. Even if it does need some work, it's still mine!:D
Thanks for reading,
T.J.
gulfcoastcruiser 01-24-2012 04:52 PM
If you are replacing all the wiring etc. inside the cabin anyway, I don't see why you could not pressure wash the inside. Just be careful that there are no exposed areas where you might force water into the core of the fiberglass. I probably would not spray the ports directly. Also, you will probably end up with a LOT of water inside the boat that will have to be pumped out. Otherwise why not.
Barquito 01-24-2012 05:53 PM
Maybe a lower volume spray, a scrub brush, and a shop-vac. Unless you completely tear the boat appart, you could be scrubbing for weeks.
The approach to the nasty/stinky boat I have is to do a basic scrubbing, targeting places you can see more than the ones you can't. Then starting with the anchor locker area, clean, prep, and paint with porch paint. Then move back one locker at a time. Boat projects always take way longer than you plan. Don't let it take away from sailing time.
I assume you have some basic resources:
catalinadirect.com
chipford.com/projects.htm
etc.
djodenda 01-24-2012 05:53 PM
I carefully pressure washed mine, which was in worse shape.
Use a wet/dry shopvac to get the water out
Not too hard...
You can do this in an afternoon if you work hard.
Barquito 01-24-2012 06:01 PM
catalinadirect.com
etc.
captflood 01-24-2012 06:23 PM
GREETINGS EARTHLINGS . you can use bath cleaner to polish the inside and make it smell nice (for fibre glass baths) I would use Oxalyic acid to clean the outside but you need to know what your doing this stuff can burn you. talk to your locan pharmacy and ask for giudence and advice (but it does bring the hull up grand) GO SAFE
dacap06 01-24-2012 09:18 PM
Wow. That's quite a project. You have your work cut out for you. I'm always amazed that people take obviously wrong shortcuts and then don't take care of the results. Even so, that boat must have an interesting story! I must say, your replacement compression post looks positively spindly.
Have fun with while your GF is gone.
Donna_F 01-24-2012 09:25 PM
Will it still have as much integrity as a straight block of wood? It looks like a stairwell post.
TravelinJack 01-25-2012 12:01 AM
I appreciate the pointers on the clean out, hopefully when the rain stops I'll be able to give it a go. I do believe I'll start with low pressure and see where that takes me.
As far as the compression post, that is what originally came with the boat. I wondered that same thing the first time I crawled in there about a year ago. All of the c-22's of that time period I've seen on sailboatlistings and similar sites with interior pictures have that same post in them. You can see it here in this ad:
1984 Catalina Sailboat sailboat for sale in Kansas
The plan is to get it all cleaned up and then take it out to my buddies hangar nearby in work on it indoors. Thanks again for all the advice.
T.J.
Perithead 01-25-2012 12:13 AM
Good deal Jack! Are their any major repairs that need to be done?
Have you considered making that blog?
