Solar deck instead of solar panels - Page 4 - SailNet Community
 5Likes
post #31 of 35 Old 01-30-2013
Re: Solar deck instead of solar panels
I have been thinking about doing this, but i didnīt for the following reasons:
-Good solar panels use special coated glass that reflect little light. Normal glass reflects a lot and cuts down on the efficiency. Gelcoat or whatever you put on there will undoubtetly be even worse than normal glas. If you make it antiskid, it will be downright terrible.
-Even little pieces of shaded cut down a lot on the energy output.
-Solar cells are very sensitive to crackling. I dont feel safe walking on them and maybe sometimes dropping pieces of stainless equipment or tools on them.
When i buy myself a campervan and i wont be dropping **** on the roof, walking on the roof and dont need anti skid, i do however intent to do this. Simply because cells are cheaper than panels and this way i dont need to build frames.
Sorry for not believing in it, it sure looks cool, and who knows, maybe im wrong
Arjen is offline
post #32 of 35 Old 01-30-2013
Originally Posted by jobberone View Post
How fragile are the current cells being used? I like the cells atop a hard binimi (saying that without any experience) and was wondering if you can walk on them.
I would think that depends on the flexibility of your hard bimini and the amount of walking you do. They are pretty fragile, if they crackle, the power output goes down considerably. If it is a really sturdy bimini and you dont walk too often on them, maybe they can handle.
Arjen is offline
post #33 of 35 Old 01-30-2013
Go Cowboys
jobberone's Avatar
Is there a transparent substance sturdy enough to walk on that still will allow enough light to be transmitted thru it? I was thinking about placing something like a plexiglass housing over it. If so would you place it on the panels or raise it up enough to not touch it?
jobberone is offline
post #34 of 35 Old 01-30-2013
outbound's Avatar
thnk
1.solar technology continues to advance. If you have panels.easier to swap out.
2.cells break ( see above) if glassed in hard to swap out.
3.angle of incident light important determinent of output.
4. maintaining integrety of connections problematic.
Did energy calc.- if I get ~3y from panels they have paid for themselves at current fuel prices.
If to put on deck would use new flexible panels and deploy as needed.
Personally spec'd cored hard bimini. very rigid platfom for panels and out of harms way.
s/v Hippocampus
Outbound 46
outbound is offline
post #35 of 35 Old 01-31-2013
Vendor
Mantus Anchors's Avatar
Originally Posted by DRFerron View Post
are you getting what you expected out of the array?
if you damage a pannel, how hard is it to replace?
Greg
Anchor Purveyor
Mantus Anchors is offline
Solar Panels dougshipl Gear & Maintenance 20 05-04-2012 11:28 PM
Where did you put solar panels? stevemac00 Pacific Seacraft 27 04-08-2011 09:00 PM
Solar Panels? LandLocked66c Electrical Systems 18 01-30-2010 11:32 AM
solar panels johnnyboats Gear & Maintenance 25 11-14-2008 09:24 PM
More on solar panels. SVDistantStar Gear & Maintenance 47 04-04-2008 07:58 AM
