Harness Attachment Backing? Is This Enough? - SailNet Community
 1Likes
  • 1 Post By mitiempo
post #1 of 8 Old 01-25-2012 Thread Starter
Montgomery 17
Perithead's Avatar
Cool Harness Attachment Backing? Is This Enough?
I purchased a attachment point to hook my tether to while I am in the cockpit. I plan to mount it just below the companionway in the cockpit so that I will be able to move about the entire cockpit and reach the base of the mast on my Montgomery 17.
The fiberglass at this spot is fairly thick, I'd guess at least 1/4" or more. I am wondering if what I have in mind is sufficient backing for the part.
The washers are fairly large and I think that they are sufficient backing for this application. I don't really have the capabilities to easily find and fabricate one large SS backing plate and I don't think a piece of 1/4" plywood would help all that much more than the washers.
If this isn't sufficient, can you recommend a cheap and easy solution to having adequate backing for this situation?
Small is beautiful, simple, cheap, and easy......
Sailing Videos, Woodworking Videos and More!
Perithead is offline
post #2 of 8 Old 01-25-2012
jackdale's Avatar
I think that should work. It has some substance to it.
jackdale is offline
post #3 of 8 Old 01-25-2012
You really are funny!!
chrisncate's Avatar
There is always Garalite (G-10) as an option, but those fender washers should work fine I'd think.
chrisncate is offline
post #4 of 8 Old 01-25-2012
mitiempo's Avatar
Aluminum is a good option as well. Scrap is not expensive and it is easy to work with.
Brian
mitiempo is offline
post #5 of 8 Old 01-25-2012
I always double up the thin fender washers. When they bend they actually crush the glass underneath and start to weaken the structure.
Gary H. Lucas
GaryHLucas is offline
post #6 of 8 Old 01-25-2012
Senior Moment Member
SloopJonB's Avatar
Originally Posted by GaryHLucas View Post
I always double up the thin fender washers. When they bend they actually crush the glass underneath and start to weaken the structure. Gary H. Lucas
That helps but you can also buy thick fender washers that don't cup the way the thin ones do.
Miti has it right though - hit a metal scrapyard and buy a scrap hunk of 1/4" aluminium plate and make a proper backing plate. You can work it with wood tools for the most part. It's stronger, neater and you get some satisfaction for a custom job, well done. If you have access to a halfway decent scrap metal dealer, it will only cost a couple of bucks for a small piece a couple of feet square.
You'll probably enjoy it so much you'll use the big chunk of leftover alloy to make new backing plates for all your hardware. Don't forget to chamfer the boltholes in your deck so they'll hold some sealant when you mount the fitting.
SloopJonB is offline
post #7 of 8 Old 01-25-2012
pdqaltair's Avatar
Just make sure that if you fall off the back...
... you won't be stuck in the propeller zone. Very bad.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
post #8 of 8 Old 01-25-2012
A New Adventurer
funjohnson's Avatar
I used thick fender washer and Wichard folding padeye for all of my cockpit mountings. I wanted to use a solid backing plate, but with the cabin liner in the way, I couldn't get to the back without cutting a large hole. I ended up drilling a center hole of 1 1/4" and feed the three washers through this hole. The liner was then covered with a white plastic plug.
1989 Sabre 34II Targa
mjsailing.com
funjohnson is offline
Halyard attachment. deniseO30 Gear & Maintenance 1 05-26-2011 11:05 AM
rock climbing harness as a sailing harness johnnyandjebus Gear & Maintenance 7 09-22-2009 05:46 PM
vang attachment bluwateronly Gear & Maintenance 3 01-28-2009 12:10 AM
8.3 Keel Attachment pnwardwell Columbia & Coronado 1 06-22-2008 03:32 AM
Forestay Attachment jkolle Gear & Maintenance 1 06-16-2006 06:56 AM
