Like Tree2Likes
Old 01-26-2012
BreakAwayFL's Avatar
BreakAwayFL is on a distinguished road
Steel plates on bow?
Hello all. I have seen some boats with a beautiful steel plate molded across the point of the bow down near the waterline. Does anyone know what this is called?
Happy Sailing,
Nelson
Old 01-26-2012
These guys call them 'bow protectors' or bow shields .... makes sense, I guess!
BowShield Stainless Steel Bow Guard and Protector | KS Marine Products
1984 Fast/Nicholson 345
Old 01-26-2012
That's very similar to what I saw, thank you!!!
Old 01-26-2012
oysterman23's Avatar
oysterman23 is on a distinguished road
Hi Breakaway
They look far more protective than I think they would prove to be...docks are higher, if a winch cable snapped it would snake and hit somewhere else, but Ill bet the real purpose is to protect from the random attack of the rabid alligator manatee....
Cod
Old 01-26-2012
sawingknots's Avatar
sawingknots is on a distinguished road
i'd say icebreaker for the more avid sailors
Old 01-27-2012
dacap06 is on a distinguished road
Send a message via Yahoo to dacap06
Everything has three names -- a scientific name, a common name, and a sailor's name. Bow protector sounds rather lubberly to my ear. I doubt that's what sailors would call it. On the other hand, what sailors call anything generally can't be used in polite company.
I honestly don't know the plate's name, but if I had to guess I'd call it a cutwater plate. I'll bet it bolts right through the hull to the cutwater backing plate, a part whose name I do know.
Tom
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
Old 01-27-2012
what ever its called if i see one headed in my direction,i'm getting the hell out of its way,perfect boat for a redneck drunk me thinks
Old 01-27-2012
chamonix is on a distinguished road
I thought metal plates on the bow where to protect the bow from the anchor when its being raised rather than to protect agianst collision?
Old 01-27-2012
Yes, I think that's the primary purpose for these plates.. we're starting to see them more now on newer boats due to the currently fashionable plumb bows which really makes getting the anchor on board without chipping gelcoat a bit of a problem.
There's an outfit that makes thin gauge self adhesive metal plates for areas like where a sheet might chafe on a coaming edge.. but I doubt they'd be much help in the bow area for anchor protections...
Old 01-27-2012
Capt Len is on a distinguished road
If you paint a mark on the anchor chain ,you can slow or stop the winch before it hooks the spot where you should have put the steel plate .If the plate has teeth , it's a beach comber boat for pushing logs around. I put a big one on the Sequel to counter bergy bits and many vessels up the inlets use them because the top inch or so of fresh freezes on the salt and cuts the hull.
Chain Plates eherlihy O'Day 11 03-28-2011 07:17 AM
Plates, glasses, etc... cb32863 Living Aboard 28 02-04-2011 09:38 AM
Backing plates micheck General Discussion (sailing related) 7 11-14-2010 01:27 AM
Just old plates, but what? 71Irwin32 Gear & Maintenance 17 03-23-2010 12:43 PM
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 03:46 PM
