5/16" Line to Small for Halyard? - SailNet Community
Blogs
Like Tree1Likes
  • 1 Post By celenoglu
Old 3 Weeks Ago
Perithead's Avatar
Montgomery 17
Perithead is on a distinguished road
Question 5/16" Line to Small for Halyard?
I am looking to run my main halyard back to the cockpit on my Montgomery 17. I have few blocks that I would like to use that accommodate up to a 5/16" line. Does this line have enough strength to be used for this on a 17' sailboat?
From what I have read from various Google finds it should be fine. Just figured it wouldn't hurt to run it by Sailnet first....
What you think?
Small is beautiful, simple, cheap, and easy......
Visit my website
! Lots of useful info and sailing videos.
Old 3 Weeks Ago
PaulinVictoria's Avatar
PaulinVictoria is on a distinguished road
I think mine are 3/8", so 5/16" would be fine on yours I think.
To err is human. To arrr is pirate.
S/V Tangerine, 1979 C&C24
Old 3 Weeks Ago
celenoglu's Avatar
celenoglu is on a distinguished road
Generally the diameter of a rope is decided according to the handling characteristics than its load carrying capacity. 5/16 is more than enough to handle your loads. The only problem is you trying to pull the rope. If you are happy with it, use it.
olson34 likes this.
Old 3 Weeks Ago
Yes, 5/16 will be strong enough; as celenoglu indicated it might be a bit hard on the hands, but for halyard use that may not be a big deal.. you're not 'handling' it all the time like you would a sheet.
If it does become a problem you can always stitch on the cover from a 3/8 double braid line for the section from the tail to where the hoisted line meets the cleat (or buy 3/8 and strip the cover of the other half..).
1984 Fast/Nicholson 345
Old 3 Weeks Ago
paulk's Avatar
paulk is on a distinguished road
What Faster said.
Old 3 Weeks Ago
Perithead's Avatar
Montgomery 17
Excellent! Exactly what I wanted to hear.
Thank you all!
Visit my website
Old 3 Weeks Ago
scotthenry is on a distinguished road
I used 1/4" on my m17 and is was fine.
Old 3 Weeks Ago
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
5/16" is fine. IMHO its more than enough. I use 1/4" halyards on my 25 footer.
Merit 25 # 764 "Audrey"
Old 3 Weeks Ago
tap tap is offline
tap is on a distinguished road
There's quite a range in how strong lines are and for halyards stretch matters a lot for top performance. The cheapest 5/16" rope you might by a hardware store isn't strong enough. But a low end sailing line like Samson LS or NE Sta-Set would be more than strong enough in 5/16". You'd be fine with 1/4". Racing dinghies with a main sail your size would use a high-tech line that's 3/16" or even 1/8".
Soft Halyard or Line Shackle allene222 General Discussion (sailing related) 0 07-04-2011 08:41 PM
PSC 31 sheet/halyard/line lengths AlLorman Pacific Seacraft 8 12-10-2010 06:56 PM
Replace Main Halyard using a "messenger" harpguitar Gear & Maintenance 16 06-15-2010 09:24 PM
Question about halyard and line colors drlove Gear & Maintenance 20 11-12-2008 07:25 PM
Halyard line size bestfriend Gear & Maintenance 1 08-07-2007 05:47 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
