hot water from the boat engine - Page 2 - SailNet Community
post #11 of 12 Old 07-25-2012
Tim R.'s Avatar
Re: hot water from the boat engine
The closed coolant system and domestic water system need to be isolated. There should be no mixing of these two systems.
When Eric references the "fresh" water side, he is referring to the engine coolant. The over-pressure valve is likely the expansion tank cap.
You need to bleed the air from the closed coolant system at the highest point in the loop. If you WH is higher than your engine, then you need to bleed the air out there. Or there should be a coolant expansion tank above the heater into which the air should normally escape. You should not need to remove a hose to bleed the system.
It can take a long time for the coolant to heat your water. Make sure you are operating the engine under load and give it at least an hour to heat the water.
If you have air in this coolant loop, your engine is probably not cooling properly.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #12 of 12 Old 07-25-2012
One of None
deniseO30's Avatar
What size WH did you get? and just because the hoses are hot from the engine it doesn't mean the heatX is not air bound. It has to be "burped" In any case the time to heat varies.
My last project!
deniseO30 is offline
beware of barefoot charters mauigirl Chartering 55 02-20-2016 05:02 PM
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 03:42 PM
Cape Fear 38 goduke Boat Review and Purchase Forum 24 06-21-2008 12:30 PM
Cat30 Exhaust riser blew up - Engine won''t start E_N_Z_O Gear & Maintenance 2 07-31-2001 07:55 PM
Raw Water in Engine wmwtlw Gear & Maintenance 3 02-25-2001 12:31 PM
