Old 01-29-2012
sailguy40's Avatar
sailguy40 is on a distinguished road
Painting aluminum mast
Doing my annual mast maintenance. I have an aluminum mast, i have noticed it looks like it used to be painted black. I guess after years of use, it has started to fade off and now just looks bad. Question is, why would anyone paint an aluminum mast in the first place? Maybe it is some type of protective paint, i really dont know. To get to the point, i am considering just repainting it. So is there any special marine paint for aluminum anyone here can recommend?
Old 01-29-2012
If it's 'fading off' rather than flaking or chipping, it was probably anodized rather than painted, which was the more standard way of doing things in the 70s and 80s. Still probably is, come to that.
When we painted our (clear) anodized mast we sanded to bare metal, mild acid wash and primed and painted with Awlgrip, a pricey 2 part polyurethane paint. It worked out very well, but as mentioned is not cheap and develops dangerous fumes requiring special protective equipment for those mixing as well as the sprayer.
You could try using the 'rolling and tipping' method, perhaps even with a single part, but as ever preparation is the key to any long lasting/good looking paint job. Keep the coating as thin as will cover.. it will last longer.
1984 Fast/Nicholson 345
Old 01-29-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Like he said.
My 60' stick was well worn - no anodizing left at all and a lot of oxidation. I stripped it to the bare tube, sanded it with discs used by auto shops - they are a resinated plastic mesh and work absolutely great in this circumstance. You use them with a small angle grinder. Some use of another autobody sanding disc - a disc with sandpaper laid around it in an overlapping pattern like shingles - also used in an angle grinder.
Some hand sanding was required in nooks & crannies then the painter went over the whole thing with red Scotchbrite pads, wiped it with sovent and then sprayed Awlgrip primer. When that was done the topcoat Awlgrip was sprayed.
Stripping the hardware from an old mast was brutal - I broke a couple of deadblow hammers. An impact driver is essential. It took about a week to clean it off except for two cleats - they weren't coming off so they became integral parts of the mast.
Doing the prep myself and just having a pro spray it kept my cost to about a grand - for a 60' mainmast, a 15' boom, a 28' mizzen and an 8' boom. About a third of that was just for the paint - 2-part poly's are worse than bottom paint.
I stupidly forgot about my spinnaker pole and jockey pole so they are still worn anodizing.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Painting an aluminum spar jarcher Gear & Maintenance 19 06-12-2011 12:10 PM
Aluminum painting issues. SiXeVeN Gear & Maintenance 7 09-01-2009 07:23 PM
Painting aluminum svindigo Gear & Maintenance 18 04-21-2009 03:19 PM
Glazing lexan and painting aluminum Alden68 Gear & Maintenance 6 04-02-2007 09:36 PM
painting anodized aluminum mroskothen Gear & Maintenance 1 08-13-2003 02:51 PM
