Palmer Engine - Page 3 - SailNet Community
post #21 of 25 Old 02-02-2012
Senior Moment Member
SloopJonB's Avatar
Originally Posted by dabnis View Post
sodium filled valves (how do they do that?) Dabnis
I think they outsource to Cadbury's who use the same process they use to get the caramel inside the Caramilk bar.
SloopJonB is offline
post #22 of 25 Old 02-02-2012
If I remember from my high school chemistry class, sodium is pretty nasty stuff, especially when you put it in water. How about it, some of you chemical engineering or other knowledgeable folks, how do they do it?
Dabnis
dabnis is offline
post #23 of 25 Old 02-02-2012
Junior member, rest old
msmith10's Avatar
I don't know how they did it but I do know why. Sodium melts at 208 degrees. It takes a lot of energy to make the phase change from solid to liquid, so the valve absorbs a tremendous amount of heat at this point without a large change in the temperature of the valve.
I remember as an undergrad chemistry student being fascinated by the concept of something catching on fire upon contact with water. I got hold of a little (1/4" cube) piece of metallic sodium. I dropped in the sink and poured some water on it, and it did just what they said it would.
I was lucky I didn't burn the lab down or get booted out of college. It was a very dramatic reaction.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #24 of 25 Old 02-02-2012
LakeSuperiorGeezer's Avatar
How Do They Do That?
... sodium filled valves (how do they do that?)...
Dabnis
Here is one way: Process for the production of a sodium-filled valve - MTU Motoren- und Turbinen-Union Munchen, GmbH
LakeSuperiorGeezer is offline
post #25 of 25 Old 02-03-2012
Ahah!!, Sloop was right.
Dabnis
dabnis is offline
PALMER 60 engine hoagy Gear & Maintenance 5 10-28-2009 08:28 PM
Looking to Replace 1957 Palmer Engine Cortona Gear & Maintenance 0 07-21-2009 08:18 AM
Looking for Palmer engine parts smurad1 General Discussion (sailing related) 1 06-12-2009 09:34 PM
Palmer exhaust help Seafarer31 Gear & Maintenance 0 05-17-2009 12:52 PM
Palmer Johnson 30 owenmccall Boat Review and Purchase Forum 0 03-10-2004 11:42 AM
