Cajun ropes - Page 2 - SailNet Community
post #11 of 17 Old 01-30-2012
Senior Moment Member
SloopJonB's Avatar
Someone asked this question some months back and got the same 100% positive responses.
SloopJonB is offline
post #12 of 17 Old 01-31-2012 Thread Starter
SloopJon, don't you wish SN would either have a better search function or fix the Unread messages feature so we didn't miss so much?
All, thanks for the feedback. I may give them a try. The post that mentioned several inches of stretch caught my attention. That seemed like a bit much, so I tried to look it up. We will use 5/8 sheets, btw. Cajun claims their line to be Low Elongation as opposed to NER, which I have now, which says Low Stretch. Is there a place with more data than that?
Jeanneau 54DS
Minnewaska is offline
post #13 of 17 Old 01-31-2012
tommays's Avatar
All the lines have % at loads figures to make comparisons BUT they do sometimes make them hard to find
Cajun also has a much higher end line of material
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #14 of 17 Old 06-17-2012
Re: Cajun ropes
I have never used Cajun Ropes, so I don't know anything about them directly. But as I understand it they use Nova Braid as a manufacturer, and they have an exallent reputation. Their prices seem to be very reasonable, and the options seem to be reasonable.
Before I did anything though, I would highly recommend you consider getting rid of double braided polyester lines (sta-set and the ilk). While polyester has been a good standby for cruisers for decades, modern lines are much stronger and much cheaper than many realize.
For most applications a modern dyneema/spectra line can actually be much cheaper than the polyester lines it might replace. My new halyards for instance cost 2/3 as much by going to tapered endurabraid as the sta-set would have cost. And have a fraction of the stretch, are thinner so they run through blocks easier, are much more uv stable, and don't absorb water.
Originally Posted by Capt.aaron View Post
I'm Glad to hear. I just re-rigged a Cal 36, all hallyard's, sheets etc. We saved over 500 dollars buying a spool on some web-site. It came to about .20 cents a foot. All 5/8. I'll check on Cajun next time I just need one line or what ever.
Capt. What did ou need 5/8 for on a Cal 38? That is massive stuff for that boat. Heck you could pick up the entire boat with a piece of that line, without coming close to breaking strength. I would be concerned that none of the other hardware would be sized appropriately for something that big (blocks, sheaves, clutches, ect).
Greg
Stumble is offline
post #15 of 17 Old 06-17-2012
Re: Cajun ropes
It's better than sta-set. If you're not going to spring for a high-tech low-stretch line, it's the best deal I've seen out there.
I do find it a little harder to splice than sta-set, but not too bad.
yossarian is offline
post #16 of 17 Old 06-20-2012
BJV
Re: Cajun ropes
we use cajun, good product and speedy service
bvander66 is offline
post #17 of 17 Old 06-21-2012
Re: Cajun ropes
Stretch isn't as big a problem with sheets as it is with halyards, particularly for a cruising boat.
We're using 3/8" Sta-Set for the heavy air jib sheets and the mainsheet. We have no complaints.
Cannot speak to Cajun ropes, as I've never bought nor used any.
Jim
SEMIJim is offline
Learning the Ropes SullivanFamous Introduce Yourself 1 06-03-2011 10:34 AM
New England Ropes Mega Plait Arclight Gear & Maintenance 7 03-11-2010 10:33 AM
New England Ropes VPC j34035 Gear & Maintenance 7 10-28-2009 01:43 PM
Cajun Rigging rireefguy Gear & Maintenance 7 05-15-2007 04:46 PM
Eager to learn the ropes dplynch33 Crew Wanted/Available 2 05-28-2006 08:53 PM
