Old 01-30-2012
Minnewaska will become famous soon enough
Cajun ropes
Time for new jib sheets, maybe main sheet too. Has anyone used Cajun Ropes XLE? The price is tempting. Durability, hand feel and kink resistance are more important, however.
I only need solid cruising lines, not racing, but quality is important.
Open to any suggestions and/or fav suppliers.
Jeanneau 54DS
  #2
Old 01-30-2012
Lake Superior Sailor's Avatar
Lake Superior Sailor is on a distinguished road
I like New England Cord, it lasts well, fair price & works well both for climbing & sailing!...Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
  #3
Old 01-30-2012
Maine Sail's Avatar
Excellent product and quite comparable to NER. It's made by Nova Braid of Canada... Cajun Ropes is excellent to deal with and very reasonable. I use the Nova Gold anchor rode and it is the best rode I've ever used...
______
-Maine Sail / CS-36T
  #4
Old 01-30-2012
g0twind's Avatar
g0twind is on a distinguished road
Bought all of my running rigging from Gary last year. He is great to work with. The kit for my boat was exactly the size needed.
Top quality rigging if you ask me.
1974 Paceship PY23 "Barely Awake"
Hull # 001
  #5
Old 01-30-2012
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
I'm using VPC for jib sheets on my 25' racer, been very happy with their performance.
I've used Samson XLS before and it works well, but wouldn't recommend it for halyards or guys. I'm assuming the Cajun brand would work fine. Pretty stretchy though.
Might want to look into a single braid for the main sheet. Salsa, Apex, Bzzz line, are all good choices. Run easily, and very easy on the hands.
Merit 25 # 764 "Audrey"
  #6
Old 01-30-2012
CLucas's Avatar
CLucas is on a distinguished road
Send a message via AIM to CLucas
+1 for Cajun Ropes. Great product, great customer service.
s/v Grey Goose
1977 Pearson 30 #995
~~~~~~_/) ~~~~~~
  #7
Old 01-30-2012
jgeissinger is on a distinguished road
Cajun Ropes
Cajun has an absolutely great product at a great price. I have used them exclusively for over a decade. The last item I bought was line to replace a spin halyard I wrecked. It was delivered to my front door in SoCal from Nova Scotia for less than I could have bought it at WM, and in my opinion it's a better product.
  #8
Old 01-30-2012
Sanduskysailor is on a distinguished road
Whatever you do, don't buy Novabraids Syntec for sheets. It sucks. Specs look good and supposed to be comparable to NE's VPC. It's not. Syntec is about the kinkiest line I have ever used. I tried everything to keep it from getting hockles. Pre-stetching, trailing the line behind the boat, washing with some mild detergent and fabric softener. Nothing works. It still has tension in it and fouls in the turning blocks on just about every tack. Line was very slippery at first and still pretty slippery. My guess is the tension in the core is not balanced with the cover. On the other hand I've heard good things about XLE for general use. Unfortunately with my Kevlar #1 XLE has too much stretch. 7/16" XLE stretches 4-8 inches in the puffs which is not acceptable in racing conditions.
  #9
Old 01-30-2012
Liquorice's Avatar
Liquorice is on a distinguished road
Cajun XLE is sort of like Sta-Set (not Sta-SetX) and is OK for cruising boats.
If you want very little streach you should consider Yale PhD (spectra/polyester) or FSE Robline (Dyneema/nylon).
Both are single braid, easy to splice, don't absorb water, cost a small fortune, nice hand!
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
  #10
Old 01-30-2012
tap tap is offline
tap is on a distinguished road
Yale PhD is makes great sheets, but it's expensive. The weave starts out very loose but the heavily loaded part of the line between the sail and cars will shrink to about half diameter. The line past the winches doesn't shrink so much. The looseness can a be a problem as it can catch on things like cleats and spin pole lock levers.
You may post attachments
You may edit your posts
Learning the Ropes SullivanFamous Introduce Yourself 1 06-03-2011 09:34 AM
New England Ropes Mega Plait Arclight Gear & Maintenance 7 03-11-2010 09:33 AM
New England Ropes VPC j34035 Gear & Maintenance 7 10-28-2009 12:43 PM
Cajun Rigging rireefguy Gear & Maintenance 7 05-15-2007 03:46 PM
Eager to learn the ropes dplynch33 Crew Wanted 2 05-28-2006 07:53 PM
SEO by vBSEO 3.6.1
