Like Tree2Likes
  • 1 Post By Faster
  • 1 Post By SlowButSteady
Old 01-30-2012
tadavidson is on a distinguished road
Removal of the Mainsail
Hi All:
I had a most unfortunate ripping of my mainsail on my O'Day 32' on my way up to Ventura, CA in a storm last weekend. I'm going to have it mended until I can gather enough clams for a new one, but does anyone know how one removes it from the boom/mast? My only experience (been lucky) needing to do this was with a 15' sailboat long ago. Seems like it would be a real beeotch. If anyone can explain it to me, I would be very grateful. :-)
Tania Davidson
Ventura Harbor
Ventura , CA
O'Day 32' Aft Cabin Caralyn
Old 01-30-2012
There should be a gate, or a gap in the sailtrack on the mast where a pin or stopper can be removed to clear the slugs off/out of the track. Then release the outhaul, disconnect the clew car and the tack pin/shackle and slide the main out of the groove in the boom forward towards the mast. If it's calm it may help to hoist the sail, open the track and peel out the slugs as you lower the sail.
If you have a loose footed main just release the corners and you're done.
If you're folding it up for transport it works better to remove the battens.
jrd22 likes this.
1984 Fast/Nicholson 345
Old 01-30-2012
Removal of Mainsail
Thank you so much, Faster! That is reassuring. Doesn't sound that bad. :-)
/Tania
Old 01-30-2012
You're welcome.. it's easy enough but it can be awkward. It's much easier with two people.. that's a lot of cloth to muscle around by yourself.
Also if it hasn't been done in a while the lock pin/stopper/whatever is used to make sure the slugs don't fall out on their own may be corroded or difficult to remove.. we can cross that bridge if it comes up...
Good luck.
Old 01-30-2012
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Handy tools to have for this might be a pair of pliers and/or vice grips, some WD 40 and the extra hand for rolling the sail up. As Faster also mentioned, don't forget to take out the battens from the sail before folding it up for storage.
Old 01-30-2012
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
If the sail has a bolt-rope on the foot (such that the rope fits into a slot in the boom), you might want to take a garden hose and spray as much freshwater into the slot as possible. If the sail hasn't been off in a while there is probably a lot of salt and dirt in there. If so, the accumulated gunk will probably make sliding the sail out of the boom difficult. If the build up is really bad (rare, but it happens), you may have to wash out as much as possible, let it dry for a few hours (or overnight), then spray a bunch of dry lube (e.g., SailKote) along the bolt-rope to facilitate getting it out of the slot.
Faster likes this.
Old 01-31-2012
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Ditto what SBS said with the sailkote, also spray the lugs or sliders as far up the mast sail track as you can reach, that will help a little sliding the sail down on out
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 01-31-2012
MarkSF is on a distinguished road
Can I add, when the sail is down and flaked over the boom, take some sail ties and tie them around the sail but NOT around the boom, just around the sail. Then the whole sail will slide forward like a vast sausage and really isn't that bad to manhandle.
Bristol 31.1
Old 01-31-2012
Yes but that's only do-able with a loose footed main.. I suspect that the OP has a bolt rope foot (but that's just a guess).
We had a 24 ft dayracer some years back, the last main we bought was bolt rope luff, loosefooted, velcro clew strap, and used only the cunningham at the tack, we took the main off after every sail by rolling it into a tube as someone eased the halyard. Worked slick.
Heavy weather: mainsail removal Hartley18 Seamanship 8 03-25-2008 03:40 PM
Winch removal kwaltersmi Gear & Maintenance 6 03-15-2008 12:37 PM
Re: Transmission Removal NewsReader Mass Bay Sailors 0 06-26-2007 05:15 PM
Name removal LH44 Gear & Maintenance 1 06-08-2005 05:11 PM
