Like Tree1Likes
  • 1 Post By hellosailor
Old 01-30-2012
rlmccb is on a distinguished road
Gel coat cracks.. what to do?
On a 1974 Islander 30 MK II what is the easiest wayh to deal with superficial cracking in the gelcoat??
Old 01-30-2012
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Two ways that I know is, sand out the area, apply epoxy primer and paint with a good 2 part polyurethane paint. The other is lightly grind the area and color match a gelcoat paste
Color matching isn't too hard but be ready to do several test samples ( about the size of the tip your pinky ) on the deck
And I think your island has a brown hue to it so, start with the paste ( white ) a small drop of white pigment and then using a toothpick a small drop of brown; (you'll be surprized at how well a drop that small will tint ) mix, then test and repeat as needed, if you go to far add some white and you might experiment with a bit of yellow.
It's not as bad as it sounds
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 01-31-2012
hellosailor's Avatar
Stick a decal over it.
If you want a proper repair, you undercut the crack (so it is wider at the bttom than at the top) clean it thoroughly, and fill with tinted epoxy to match the deck. Sand and polish as necessary. That will still never match 100% unless you've got a damned good eye and good luck, so now you get custom tints and a gel coat repair and try to spray and blend to hide the work. Unless you have a very good eye and some practice at this, you're better off stopping at filling the cracks, and call a pro if you really want to hide it afterwards.
Or apply anti-skid deck paint to that whole area.
Or cut a hole and install some new piece of equipment or a porthole there. :-)
Faster likes this.
Old 01-31-2012
Thanks for the pointers!
Happy Sailing
Rick
Old 01-31-2012
MarkSF is on a distinguished road
So far I've used white MarineTex for a few chips, screw holes, and so on in the white gelcoat. Is this OK? It is tinted epoxy after all.
I have a couple of gelcoat cracks and I'm considering using it for those.
Bristol 31.1
Old 01-31-2012
MarineTex works. It is a high quality tinted epoxy putty.
Old 01-31-2012
Sublime's Avatar
Quirky
Sublime is on a distinguished road
If they're really superficial cracks and you're not worried about any damage to fiberglass underneath, here you go: gel-paste
I had to repair a bunch of those types of cracks. I used a dremel to basically widen the crack to a v-shape. You tint that gel paste as you would gelcoat then use it to fill the widened cracks. Some sort of plastic spatula would give you a nice level fill.
Make sure you get the white and not the clear. If only clear is available, don't try and tint it. Trust me, it would be a mistake. I'm not too sure why they sell clear.
Also, check the date on it in case whoever you get it from doesn't sell it often. If it's out of date, it turns blue when you add the hardener.
I don't remember if you have to cover it or coat it with mold release for it to harden.
A ship in harbor is safe, but that's not why ships are built.
My girls:
1974 Alcort Minifish-Minifish
2001 Drascombe Lugger-Penelope
2004 Hunter 260-Miss Muffet
Old 02-01-2012
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Fixing the spider cracks on the deck of my boat is still on the "mañana list" (it has a LOT of company), so I've never actually used this stuff. But, apparently it's made for just this sort of problem.
Old 02-01-2012
rg500 is on a distinguished road
it worked for me....
photo essay, fixing gel coat cracks scottyt Gear & Maintenance 1 03-22-2009 10:12 PM
What is the best way to repair cracks in the gel coat saurav16 Gear & Maintenance 29 10-17-2007 09:03 AM
What is this? Cracks in gel coat leaking a brown dry goop! Lancer28 Gear & Maintenance 12 09-13-2007 11:18 PM
Hairline Cracks on deck in Gel Coat Windermere Gear & Maintenance 8 07-10-2007 11:03 PM
Gel coat cracks seac Gear & Maintenance 3 12-13-2002 05:46 PM
