Old 01-30-2012
steveg353's Avatar
steveg353 is on a distinguished road
Traveler block
I have attached a pic of a shoddy traveler block attachment that I inherited. I think the traveler was not originally intended to be controlled with lines.
As you can see, the plate that the block is on is attached to the car with one bolt and the stress bends the plate (sorry if I don't have the nomenclature correct).
I have not been able to find a block configuration online that looks like it would work so I am asking for suggestions.
Also, what is the working load of this block on a 34'er....there is a 2 pulley block on each end of the traveler.
Old 01-31-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
I've got the same track & car on my 43' except my car has 8 bearings instead of 4. Mine wasn't set up with blocks for control lines - it has the old spring loaded stoppers instead.
It looks to me as if the line control blocks you have are simply undersized - they look like dinghy hardware. Can you find a similar replacement that's a little more skookum?
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Old 01-31-2012
celenoglu's Avatar
celenoglu is on a distinguished road
180 degree inverting the available blocks will help to decrease the bending load. Remove and reinstall the blocks upside down.
Old 01-31-2012
overbored's Avatar
overbored is on a distinguished road
looks like a Ronstan cheek block that they modified to use there. inverting them will just make them bend up instead of down. you need a block that has the eye in the center of the block so the load will be inline with the block
"FULL TILT" SOVEREL 33
"GOLD RUSH" PRINDLE 16
Old 01-31-2012
steveg353's Avatar
I agree that turning them 180deg would reduce the bending load a small amount but I would rather replace with a more substantial block. As SloopJonB said, "they look like dinghy hardware".
The problem is that I cannot find a single pully block with a center lined eye that includes a becket for attaching the end of the traveler line.
I am also unsure how to calculate what the working load will be. I guess it cannot be too much if this setup hasn't blown apart yet...but I would like to know for when I purchase new blocks.
Old 01-31-2012
Gary3675 is on a distinguished road
On our old boat I believe we had the same Traveler. We placed or screwed a pad eye to each side of the traveler and then attached a block to the pad eye. (1 hole attachment with loop. called an eye strap) This allows the block to move....I believe we put a double block on the traveler car to make it easier to adjust..
Old 01-31-2012
Yeah... I'd be doubling that tackle, that's not exactly a low friction traveler car. And use swivel blocks so that they'll align with whatever load/lead is there. This will likely involve modifying the car as Gary above suggests.
1984 Fast/Nicholson 345
Old 01-31-2012
No need to modify just replace the block with an eye strap(use the screws that is holdind the block in place for the eye strap) Then attach a new block to the eye strap
Old 01-31-2012
SloopJonB's Avatar
All good advice but I'd like to point out something I noticed after reading Cleloglu's reply. A closer look at the picture leads me to believe that the tension on the lines under discussion is in line approximately with the horizontal pivot shaft of the traveller car. If that IS the case, flipping the small blocks upside down might be enough to fair things up.
Certainly worth a try before making significant expenditures.
P.S. to calculate the loads, go to the U.S. Sailing site - they have wind load calculations, which obviously depend on the area of your main.
Old 01-31-2012
Brent Swain is on a distinguished road
I build all my own blocks , for around $2 worth of materials and 20 minutes work. I just cut the cheeks out of 3/16th aluminium sheet, leave them attached by a 1 inch wide strip for the becket, file the edges round and smooth, fold the becket 180 degrees and put the sheave in on a 3/8th ss bolt. The sheaves I cut from a half inch sheet of poly cutting board type material, with a hole saw. Then I clamp it in a vise and file the groove in with a round rasp. A billionaire couldn't buy a more reliable block for any amount of money. A block is an extremely simple device, for which there is no excuse for the cost and flimsyness of commercially made blocks.
Brent Swain, Yacht designer, Builder, and author of "Origami Metal Boatbuilding"
PSC 31 traveler AlLorman Pacific Seacraft 1 11-16-2010 05:37 AM
Help with Traveler asdf38 Gear & Maintenance 5 09-14-2010 04:36 PM
Traveler...for you. knothead Off Topic 10 12-17-2008 08:33 AM
The scent of Block Island (Block Island Times) NewsReader News Feeds 0 09-15-2006 10:15 PM
Rigging a block-to-block boom traveler? GC20Squid General Discussion (sailing related) 3 03-23-2006 09:31 PM
