Old 01-31-2012
Undadar's Avatar
Undadar is on a distinguished road
Toe Rail
Howdy,
My boat is a Hunter 34 with an aluminum toe rail. The PO had "sealed" between the toe rail and hull (inside of rail) with clear silicone. I know this is nearly always a bad thing. I have removed most of the silicone and mold that grew underneath it.
Question is: should this area be sealed or treated in any way? If so, what is the best thing to use? Seems to me that it should not but figured I had better double check.
As an aside, the PO had also attached a wood "rail" to the aluminum rail. This looked ok initially but was in need of maintenance so I removed it. Looks better now, me thinks. Before and after photos in this blog entry.
Thanks!
We learn from experience that men never learn anything from experience. — George Bernard Shaw
Old 01-31-2012
sawingknots's Avatar
sawingknots is on a distinguished road
i don't see any benefit to putting sealer under a toe rail except at the screw holes,no sealer, that area can dry out quicker,sealer will invariable retain mosture,perhaps a strip of butyal tape slightly wider than the screw holes
Old 01-31-2012
..especially 'clear silicone'... usually the 'vinegary smelling' stuff that really has no place on a boat. And quite difficult to fully remove.
I can't recall if that particular vintage of Hunter has the out-turned hull deck flange.. I think it does.. in which case leaks into the hull are extremely unlikely and I can only imagine the 'sealing job' had to do with the ill-advised wood rail addition.
Much cleaner look without, and a lot less work.
1984 Fast/Nicholson 345
Old 02-01-2012
Undadar's Avatar
Thanks guys. In my case, the silicone was not under the rail but rather on the inboard side of the rail. I've added a couple photos to this post on my blog - hopefully that makes it clear.
Faster: I did some research on deck flange styles and understand now what you are talking about. You are correct, it is an out-turned style.
use of toe rail.. sweetdreamyamaha Seamanship 13 08-15-2010 02:21 PM
rub rail ncsc Cal 14 09-22-2009 05:15 PM
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 09:28 AM
Rub rail brak Gear & Maintenance 4 05-06-2008 03:33 PM
Toe Rail And Rub Rail C&c FRANK PALERMO General Discussion (sailing related) 1 10-08-2006 09:14 PM
