-   -   Jouet 37 rudder modified (http://www.sailnet.com/forums/gear-maintenance/83385-jouet-37-rudder-modified.html)
Yucatancruiser 02-02-2012 01:40 AM
Hello! I own a 1979 French build Jouet 37 sloop, and the rudder seems very hard on the tiller while sailing. Also I find it hard to turn and particularly in reverse, the boat just goes pretty much anywhere. Does any body have any advise on what might be the problem, or even better is someone has the same boat, does it perform the same way. I have come to the conclusion that my rudder may have suffered some modification from a previous owner, but by just looking at it, it looks fine.
Brent Swain 02-02-2012 02:53 AM
Could you post a picture of your underwater profile and rudder shape?
Faster 02-02-2012 03:01 AM
http://i213.photobucket.com/albums/c...45/Jouet37.jpg
The rudder looks kinda small and not too well balanced, I'm not surprised you'd have some helm issues. Otherwise, though, she looks the type of boat that should back up well. What prop are you running?
Brent Swain 02-02-2012 03:18 AM
Raking the rudder post aft reduces it's effectiveness ,but yours doesn't look all that bad. Check the bearings for binding. I recently had to jack the rudder out of a Finot design with a hydraulic jack.The bearings were that badly bound. Flexing of the skeg will tend to bind the bearing at the hull joint.
celenoglu 02-02-2012 03:39 AM
The lower bearing is responsible for hardness. The plastics used for these bearings generally absorb water and cause this problem. Replace it.
The rudder generally does not respond well when astern. This is due to the effect of the propellor not the rudder. After the boat starts to move astern, water will pass from the rudder and the rudder will be affective. Allow some time until the boat starts to move astern and the rudder will be responsive.
Yucatancruiser 02-03-2012 01:44 AM
Well the rudder it self moves just fine, so i donīt think the bearings have any problems. here is a picture i took of the rudder the day i purchased the boat. Shape of the rudder and the size is what i think is modified.
http://i1245.photobucket.com/albums/.../solotimon.jpg
Yucatancruiser 02-03-2012 01:48 AM
pic of some other jouet 37
i also have a picture of another boat i found on the internet, and that is where Iīm concluding that is not shaped correctly. The diagram that by Faster is the same diagram that came with my boat.
http://i1245.photobucket.com/albums/...ene/lafoto.jpg
Yucatancruiser 02-03-2012 01:53 AM
My rudder as it is now
Yucatancruiser 02-03-2012 01:54 AM
Pic of some other jouet 37
Faster 02-03-2012 02:04 AM
Definitely looks like the balancing tab is missing from your rudder.. This would lead to a heavier helm than designed. I think that would be a reasonable project to undertake if you're comfortable with glass work.
Not sure those mods would address your issues backing up... I'm guessing that may be more prop related.
