-   -   Transducers and depth sounder High teck (http://www.sailnet.com/forums/gear-maintenance/8341-transducers-depth-sounder-high-teck.html)
obiec 10-22-2003 04:37 PM
Dose any one out there know, if you buy a transducer that is the same MHZ as the one that you depth sounder works with, will it work even if it is a diferent brand.
GordMay 10-23-2003 12:04 AM
I believe that Depth Transducers (and cable) are also impedance matched to the instrument. You cannot even cut out a bad section of cable (& re-splice) with an OEM ''ducer.
This would suggest that ''other'' brands may not work properly, unless you are "lucky" enough to locate an exact match (frequency & impedance).
Regards,
Gord
GordMay 11-06-2003 07:56 AM
Try asking Airmar regards your specific application @
www.airmar.com
or look at their cross-reference guide @
http://www.airmar.com/pdfs/xref/xref.pdf
Regards,
Gord
joub 11-08-2003 03:47 PM
I recently replaced my Signet depth sounder with a Standard Horizon unit. Since they both operated on 200Khz, I connected the new Standard Horizon unit to the existing Signet transducer....it works fine. Sure saved a lot of work installing a new transducer!
I suspect that most 200Khz transducers are interchangeable. At least it''s worth a try as it was in my case.
Jim
