Blogs
User Name
Old 10-22-2003
rlee rlee is offline
rlee is on a distinguished road
transmission not engaging
the hurth transmission on my 1982 pearson has recently been taking 5-6 seconds to engage after shifting into either forward or reverse.
any ideas on the cause or fix?
thanks -- rlee
Old 10-22-2003
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Moderator
Jeff_H will become famous soon enough
I don''t know the specifics but when was the last time you changed or checked your transmission fluid. I found that makes a big difference. Also check your shifter cable adjustments.
Otherwise, you have might have aging clutches.
Old 10-23-2003
The transmission fluid was the first thing I checked -- it was fine. Then I retensioned the cable, but still no improvement.
I guess it''s the clutches.
thanks
Display Modes
vB code is On
transmission question almostbroke Gear & Maintenance 8 06-05-2004 01:06 AM
Transmission Engages while in neutral...? kmeeks Gear & Maintenance 1 02-18-2004 09:56 AM
Leaky transmission Volvo Penta 2003 ekhar Gear & Maintenance 0 08-15-2002 05:54 PM
Transmission issues jmlawrence Gear & Maintenance 1 05-07-2002 09:56 AM
Velvet Transmission manual AndrewB Gear & Maintenance 0 08-22-2001 08:05 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
