Vinyl Fabric Replacement
Just looking to get some input on how others have replaced the vinyl on the ceiling of their boats. The visible side was mold free but in my curiousness I pulled down a corner and looked at the back side and there sure was a lot of mold.
The existing stuff was stapled around the edges no glue at all, is it possible to glue vinyl to fiberglass or is it better to staple. If so what sort of glue have you used? Any input would be extremely helpful before I begin this weekend. |
Contact cement is your best bet. I did the same thing to my CS30, not because of mold but because of rips. 2 years later and still holding strong.
Up vs Sideways
'Most any good upholstery stop can source the material, and there are 'net sources also. Taken care of, that tough stuff can last the life of the boat. If leaks are ignored or the interior is allowed to remain damp, there will be mold problems. |
I ripped all of mine out. Was falling apart, moldy and was stapled on like yours.
I am replacing it all with panels so they can be removable to access wiring and deck fittings. |
I'm planning something similar. I'm not sure the best way, but found this interesting: The Frugal Mariner: Insulating your boat
Thanks for the link. So far there have been 17 hits from this link. My chest (or maybe my head) kind of swells up when something I've written about gets noticed.
vinyl etc
Hi funny this came up today, I was just doing test laminations with a variety of commercial spray glues (my usual commercial contact for laminates, Wilsonart for Foam and delicates, Titebond Super Strength.
All adhered well in average lay up time (shop was abit cold today) but I brought them home to cure tonight before doing a peel test. The layup I did was fabric backed premium vinyl to high density foam (3/4") On brief observation it seemed to me the original toxic as hell good old fashioned stick mica to anything glue was better adhered to the foam but we will see for sure after the peel test tomorrow....hope this helps.....incidentally all layups were spray both materials dry to tack then rolled contact with typical rubber laminate roller. ChrisCod;) |
| All times are GMT -4. The time now is 11:29 AM. |
SEO by vBSEO 3.6.1
