Re-bedding deck hardware - SailNet Community
post #1 of 7 Old 10-23-2003 Thread Starter
I am about to do the dirty to my Santana 35, and have been wondering about the details. Instructions say to lightly screw the hardware down on top of the polysulfide until a little squeezes out, and then let it set for about 24 hours before tightening down all the way. I am not near the boat, and will not be able to get back to it 24 hours later. Would I be better off tightening down three or four hours later when I leave, or waiting until I come back a week later to tighten down all the way?
drynoc is offline
post #2 of 7 Old 10-23-2003
ASA and PSIA Instructor
I''d wait the week. Be sure to fill the threads of the bots with sealant before you insert them, and have someone screw the nut on while you hold the bolt head - so the sealant isn''t driven out of the threads by turning.
If you have hardware monunted on cored deck surface (a common no-no) this would be a good time to look at eliminating the risk of wet core by digging back the core and creating an epoxy plug for the bolt to pass thru. If you do a Google you can find instructions on doing this - here''s one:
http://www.nsc.ca/techtalk/rebedding_deck_fittings.htm
I like the recommendation about using butyl tape, as our builder did, but I could not find it in local marine stores..
Good luck.
sailingfool is offline
post #3 of 7 Old 10-23-2003 Thread Starter
Yes, but....wouldn''t the butyl tape prevent the hardware from touching the deck, thereby causing the hardware to deck connection to be uneven? Or do you completely fill the area under the fitting with the tape, and then cut off the remaining when the fitting is in place?
drynoc is offline
post #4 of 7 Old 10-24-2003
Best way -
overbore each hole by using an bit 1/8th inch larger than the hole. Fill with thickened epoxy (use clay underneath to stop drips). Redrill correct size. Don''t tighten all the way till sealant cures - a week is ok.
This method takes longer and is a pain, but you will NEVER get a leak into your core. When it''s time to rebed, just clean it up and reseal.
fourknots is offline
post #5 of 7 Old 10-24-2003
mikehoyt's Avatar
re BUTYL ...
I replaced my windows two years ago. The originals were bedded with Butyl rubber.
That stuff gets EVERYWHERE! It was a bitch getting rid of it all. Made getting the deck prepped for refinishing very difficult.
On the positive side it sure was not hardened.
Mike
mikehoyt is offline
post #6 of 7 Old 10-28-2003
Butyl is an automotive product--check a NADA store. Last time I checked, it was black only.
mcain is offline
post #7 of 7 Old 11-02-2003
drynoc,
In the cooler months polysulfide (ps)and 5200 long cure will not cure in a week, so you could come back a week later and finish.You can also use 5200 quick cure,tighten down ''till it squeezes out and tighten the rest of the way just before you leave.
The main thing here is that after snugging down initially and squeezing,is that both surfaces being bedded be completely covered so no water creeps by. Really, after accomplishing this the 5200 or ps can completely cure before tightening down the rest of the way. This may sound kinda scary to some but after you''ve made the soft gasket by snugging and squeezing, and bonding has taken place,it''s pretty much a dun-deal.
Dennis
windship is offline
1976 41'' TA CHIAO CT ?????? hyway Boat Review and Purchase Forum 21 07-29-2016 10:46 AM
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Crackling deck on an ericson-27 marcberoz Boat Review and Purchase Forum 0 01-04-2004 03:02 AM
