04-25-2012
Re: Rigid Boom Vang
Originally Posted by casey1999
I am also considering adding a rigid boom vang primarily to make reefing easier. Do the rigid vangs increase the chance of breaking your boom at the connection of the rigid boom vang, or breaking your gooseneck. The forces of the rigid vang are much different than those of a topping lift.
I don't think those concerns are, in fact, concerns. The support function is a 'push up' rather than a 'hold up' of a topping lift, no real difference otherwise.
Depending on what sort of rigid vang you choose, you need to be sure the support function is off (if it's selectable as some are) before tensioning the sheet.(ie make sure it's in 'VANG' mode) Most spring or gas cylinder supported styles won't have this issue.
1984 Fast/Nicholson 345
