03-20-2012
Barquito
Re: Deck - Hull Sealant....
Thanks Snow. I hope she will look a lot better after painting this spring. My last boat was a C22. There are a few pictures in the 'Low Buck Projects' thread somewhere.
Regarding the hull-to-deck joint: My Bristol 27 has Butyl original from the factory (circa 1975). My Don Casey book suggests taking all fasteners out, and prying the deck up just enough to squirt some sealer in. If you are not going to be lifting the deck up then you don't need an adhesive, so 5200 would be overkill. I plan on just scraping everything I can out of the joint and re-sealing. Not sure exactly what to use either...
