Like Tree1Likes
  #11 (permalink)
Old 02-07-2012
LakeSuperiorGeezer's Avatar
LakeSuperiorGeezer is on a distinguished road
Corrosion and How to Find It
Originally Posted by hellosailor View Post
"Change one...change them all... "
Amen.
If you aren't sure what counts as a crack, go to any auto parts supply and buy some dye check, used for inspecting metal parts. Clean the part, apply the dye, wipe off, apply the "developer" and you should be able to see dye in any cracks. Hardest part of it is finding the dye--but any real machine shop or auto repair supply will have it.
This works. There are other ways to check also:
BoatUS: Seaworthy
Sailboat Rig Problems - J. Stormer
  #12 (permalink)
Old 02-07-2012
peterchech is on a distinguished road
K that is pretty unanimous thanks!
I was hoping I could save some money by keeping the existing turnbuckles, but I have a feeling that the rigging may not have been replaced since 1981... If so, and if I inspect all the turnbuckles and they aren't cracked and still turn, are they good? Or is fatigue a problem with turnbuckles like it is with the wire and swages?
  #13 (permalink)
Old 02-07-2012
knothead's Avatar
Yes, the bronze turnbuckles can be reused unless they have been damaged, are galled or frozen or you just want to spend money for nice shiny chrome. Bronze doesn't have the same problems that stainless steel does.
Yes, the economy could use the money, but you probably could too.
Ron Paul 2012
"wikijar"
galvanic corrosion ezbreezes1 Caliber 2 05-11-2010 08:37 PM
Corrosion question: what is going on and what do I need to do about it? Northbeach Gear & Maintenance 18 07-26-2008 07:48 PM
Swage Corrosion tdw Gear & Maintenance 17 06-18-2007 12:47 PM
Rust and Corrosion. wind_magic Gear & Maintenance 4 06-17-2007 10:13 PM
External Corrosion bob1956 Atomic 4 4 04-20-2007 11:59 PM
