Old 02-06-2012
follysurf is on a distinguished road
Mast Step Corrosion
So, I recently dropped my mast and in the process of bringing it down the mast step was detached from the boat and is 'permanently' stuck in the base of the mast.
Any ideas or types of solutions that could eat away the corrosion so the step can be removed from inside the mast?
This weekend I tried using PB Blaster to seperate them with no luck. I have also used an old screwdriver/ hammer combo to try to knock it out (carefully)with no luck.
Old 02-06-2012
fordo is on a distinguished road
I have heard that soaking it in Coca-Cola ovenight will dissolve the corrosion. Haven't tried it myself but it comes from a reliable source. Good luck.
Old 02-06-2012
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Heat it gently with a propane torch... add PB Blaster... bang it with a hammer a few times... repeat until you get results.
Remember, the butt of the mast has to take all of the load induced by the stay/shroud tension plus the weight of the mast. If the corrosion is bad enough you may have to look into getting the butt (bottom) of your mast redone. Not terribly cheap, but a fraction of the cost of a new mast.
Old 02-07-2012
SimonV's Avatar
Wish I never found SN!
SimonV will become famous soon enough
If you can soak it in a bucket of white vinigar over night or longer.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Brisbane Queensland
DELIVERY SKIPPER
Old 02-07-2012
Minnewaska will become famous soon enough
Vinegar will eat at the corrosion as well as the metal. I might try it, but would not leave it overnight. At most, I would check each hour. You might also find that you permanently discolor the outside of the mast, due to the subtle acid etching.
I would try heating the mast first, as mentioned above.
Jeanneau 54DS
Old 02-07-2012
I will try the heating idea. I guess the key is to move the flame around so as to not damage/ deform the base of the mast in the process. Does heating the outside of the mast loosen up the connection/ corrosion on the inside. Obviously I can direct the flame at the joint of the step and mast base on the outside. The step goes about an inch deep into the mast.
I do like the coca-cola idea as well. It is good at cleaning corrosion off of battery terminals so it should probably work here as well.
Thanks for the help!
Old 02-07-2012
mm2187 is on a distinguished road
I would be very careful using heat and oils to remove at the same time!
Schock - New York 36
Portsmouth, RI
Old 02-07-2012
MarkSF is on a distinguished road
Everything I have read on the subject suggests that PB blaster is the most effective penetrating oil you can buy. However it might need a week or two to work.
Is it really getting into the siezed joint? If not drill a hole or two in the mast so that it can.
It would also help if you can apply continuous tension. Can they lift the mast while you suspend a weight from the mast base? Or rig some tackle to pull on the mast base against the mast?
Bristol 31.1
Old 02-07-2012
Rockter will become famous soon enough
It really can sieze very solid.
It may need some persuasion.
I guess heat, and mild hammering, and penetrating oil, and vinegar, and Coca-Cola will all have to be tried, methinks.
Old 02-07-2012
What you need to do is spray PB blaster daily. It might take a week or two to work.
Your problem when applying an impact is that it will try to twist the mast base in the mast which will make it more stuck.
However if you do want to try impact, a screwdriver and hammer are worthless. Get a large cold chisel and a large, heavy lump hammer. These will apply far more kinetic energy than a hammer with much more control and safety.
Then apply impact on alternate sides of the mast so as to even out the force. I'd suggest a few days, at least, of regular PB blaster applications before you try this.
A guy on the Jaguar forum had an XK cylinder head stuck to the block. He got a hoist, and suspended the entire front end of the car in the air BY the cylinder head (bolts removed). Then he sprayed PB Blaster on, every night. After 8 days he found the car on the ground and the head in the air.
Bristol 31.1
mast corrosion - how serious? pic attached tominny Gear & Maintenance 9 01-05-2012 03:35 PM
corrosion in aluminum mast - options samgary Gear & Maintenance 5 12-09-2011 02:04 PM
Is there a step by step for a stepping of the mast? GilStump Gear & Maintenance 5 07-15-2009 07:45 PM
Mast Corrosion? greencaptn Gear & Maintenance 3 07-09-2007 04:11 PM
Mast Corrosion Repair oldguyflier Gear & Maintenance 5 04-15-2007 11:06 PM
