Like Tree3Likes
  • 3 Post By Cherp
Old 02-07-2012
willynilly is on a distinguished road
After 4 years, what should be serviced?
Time to take my '84 33 Endeavour to a sailboat pro. I keep her at a power-predominant marina, but I found her at a sailboat oriented broker in Oriental (about a three day cruise). I've only done the usual winterizing and had the bottom checked and painted last year. I'm interested in having an expert look at the rigging. What should be examined? There's no obvious rust, no cracks, no loose fittings or cables. Some bulbs need replacing, and the VHF antenna and Windex need repair as a result of hurricane damage. Any thoughts? I saw Giulietta's rigging post, but most of it is Italian to me. I'll be taking her to Sailcraft if anyone knows about this reputable boatyard that gave me great personal service when we purchased and had the survey done. As always, thanks in advance and fair winds to you!
Willy-Nilly
1984 Endeavour 33 sloop
Albemarle Sound
Old 02-07-2012
Bristol 45.5 - AiniA
killarney_sailor is on a distinguished road
If it is a reputable boatyard they will know what to do. You want to make sure that a rigger looks at the rigging (well, d'oh - what I mean is not the guy who does the bottom paint) and goes up in a chair or harness to look at everything. While there he can replace the VHF antenna, windex, and bulbs. None of these things take any time at all. If you sail much at night or anchor - you may want to get the bulbs replaced with the correct LED replacements - they make a tremendous difference in reducing power demand. From your description it sounds like your rigging is in pretty good shape unless there is something wrong somewhere higher up the mast. If you have not checked out the physical condition of your chain plates you might get the yard to have a look at them.
Back in Brisbane. Have paid the entry fee for the Sail Indonesia Rally at the end of July, so I guess we are going to Indonesia and then South Africa. You can check OnAinia.blogspot.com for updates on our travels.
Old 02-07-2012
FSMike is on a distinguished road
If that's the original standing rigging it should be replaced. Many problems cannot be detected without x-ray, which can be near as expensive as replacement. You can also have dye tests done on fittings, etc., but if it's that old it should be replaced.
Sail Fast Live Slow
Old 02-08-2012
Cherp
Cherp is on a distinguished road
The owner should be checked - heart rate, wallet capacity, panic absorbtion ratio, alcohol consumption ability etc.
Old 02-08-2012
olson34 is on a distinguished road
Thumbs up
"Plus One" on that advice.
L
Old 02-13-2012
Thanks for the valuable advice. Wow! Replacement! Better safe than sorry.
Willy-Nilly
Albemarle Sound
Old 02-13-2012
MarkSF is on a distinguished road
Especially before presenting him with any large bill.
Bristol 31.1
Old 02-19-2012
Like this?
16 years on a 28' BCC Tuntsa Introduce Yourself 2 10-18-2011 02:17 PM
Good Years and Bad Years MooreVOLS Boat Review and Purchase Forum 7 08-26-2010 11:04 AM
your boat for 2 years, my house for 2 years wantogonow Cruising & Liveaboard Forum 0 08-27-2009 04:42 PM
What did YOU do on New Years Eve? cardiacpaul Off Topic 2 01-04-2009 01:09 AM
911, Seven Years Ago RickQuann Off Topic 7 09-10-2008 10:41 AM
