Refinishing brass - SailNet Community
post #1 of 2 Old 10-25-2003 Thread Starter
Refinishing brass
I''m sure some of you have run into the same problam as mine.
It seems brass hardware has a laquer coating. Cleaning up brass light fixtures and instruments leaves a light yellow washed out look. I''m sure it wouldn''t hold up worth a darn even if I could stand the awful color.
It seems to get the rich look of the new piece there is a coating applied.
What is this coating and where can I get it?
twilk is offline
post #2 of 2 Old 10-25-2003
Refinishing brass
I bought a spray can of laquer for painting brass and other bright metals, probably at Home Depot. It works fine on brass items around the boat. It won''t take a lot of abrasion, but works fine for maintaining the polished finish. It darkens the brass color very slightly, if that is what you are looking for.
Can''t give you the product name as the can is on the boat, but am sure you can find a similar product if you look around a little.
Jim
joub is offline
Refinishing interior teak KenD Gear & Maintenance 9 11-19-2012 07:03 AM
Teak refinishing and repair Waterline Gear & Maintenance 21 06-10-2010 02:21 PM
Bottom refinishing on trailer? aflanigan Gear & Maintenance 2 10-10-2003 03:10 PM
Installing a Brass keel shoe Joshuadawn Gear & Maintenance 3 11-13-2002 04:50 PM
teak refinishing jproctor Gear & Maintenance 3 04-22-2001 05:47 AM
