Old 10-25-2003
graham1 is on a distinguished road
Siphon break question
The intake to my electric head is plumbed as follows: from the thru-hull to the siphon break to the pump that takes water into the head. (The siphon break is a rubber "duck bill" type). It seems to me that the suction the pump makes bringing the water over the siphon break will be enough to open the break and suck in air.
When I cover the siphon break with my thumb, it brings in water. When I stop pumping and take my thumb off, I can hear air bleeding in and then I can''t bring in any more water no matter how long I pump.
I don''t think a rubber type siphon break will work on the suction side of a pump and the only solution is to use a solenoid. Am I right?
Old 10-26-2003
WHOOSH is on a distinguished road
Graham, the set-up you''re describing is commonly done...and when the siphon break prevents the pump from working well (after all, it IS breaking the siphon...) then it''s either removed or defeated. You want the siphon break on the INcoming line to be between the pump and the bowl. That way the pump is not affected, yet the pump can''t feed the bowl and overflow.
Obviously, the other siphon break is downstream of the pump. Both breaks should be mounted above the dynamic waterline, meaning as high as you can get them for ease of mind.
A solenoid will make things even MORE complicated. You''ve already done this by virtue of using an electric head; no reason to compound the problem further.
Jack
Old 11-12-2003
Thanks for the reply, Jack.
While I agree with the comment about an <electric> head, there were other considerations.
Graham
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
GPS question wallm General Discussion (sailing related) 13 05-30-2004 02:10 AM
leak from engine raw water siphon break i670684 Gear & Maintenance 2 08-11-2003 05:53 AM
question on sails Mark_OD23 General Discussion (sailing related) 6 11-19-2002 04:41 PM
Chainplate break!! MikeToogood Gear & Maintenance 0 02-20-2001 02:55 PM
