Old 02-11-2012
JSailer's Avatar
JSailer is on a distinguished road
Fire extinguisher
I need to have my engine compartment fire extinguisher checked.
I do not know the last time it was done.
I am assuming it has to be weighed and the cartridge has to be tested or changed...
Any advice or feedback from experience?
Who do you go to for something like this?
And how often should it be done?
Thanks.
O'Day 30
South Florida
Old 02-11-2012
tommays's Avatar
They sell marine UL units at home depot unless its some kind of giant unit a new would cost less than testing
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 02-11-2012
JSailer's Avatar
Thanks but maybe I didn't make it clear that it is an automatic, thermo-discharged bottle, mounted inside the engine compartment.
Not a hand bottle.
Is that what you were referring to?
O'Day 30
South Florida
Old 02-11-2012
Minnewaska will become famous soon enough
Try a local commercial fire extinguisher company. The ones that certify the extinguishers in commercial buildings. It can be as simple as certifying it visually or as complex as discharging, then testing the integrity of the bottle and refilling. Some bottles will expire after a period of time and beome unserviceable.
Which unit do you have? Talking with the manufacturer might help too.
Jeanneau 54DS
Old 02-11-2012
JSailer's Avatar
Thanks. I will have to look closer at the one I have.
Last time I looked, I could not really read any markings as the bottle is old.
I'll take it out to check.
O'Day 30
South Florida
Old 02-11-2012
LinekinBayCD is on a distinguished road
You didnt say what the agent was. Given that it is old and in an engine compartment it may be a Halon extinguisher which is no longer available. It would need to be replaced with a Halatron extinguisher.
Do you have an automatic engin kill for the extinguisher? I believe that that is required with a Halon or Halatron automatic system as the air intake would draw the agent out of the compartment renderiing it ineffective.
Old 02-11-2012
JSailer's Avatar
No, I don't know what the agent is but like you said, based on age alone I too would bet it is halon.
No engine kill.
O'Day 30
South Florida
Old 02-13-2012
I considered going with a automatic system but between the system itself and the auto kill for the engine it was at least triple the cost of a fire port and manual Halotron extinguisher before any installation costs. Not much to install with a manual extinguisher. Drill a hole for the fire port and find a place to hang the Halotron. They are significantly larger than the typical marine extinguisher my guess is if you ever need to use it you'd be wishing they were larger.
Old 02-15-2012
JSailer's Avatar
I'll look into that option if I can't get the existing bottle to be signed-off.
Thanks.
O'Day 30
South Florida
Old 02-15-2012
Our boat came with an auto discharge (not Halon, though initially I thought it was). I've been able to have a fire ext service company sign off on it twice.. as long as the weight is legit it's good to go.
Unbelieveably I've made that trip twice, and never been charged for the service. The second time I did buy a new extinguisher to replace an old non-rechargable, but the rest of the service was gratis... unusual in this day and age.
1984 Fast/Nicholson 345
fire extinguisher QuickMick Gear & Maintenance 3 07-20-2010 02:30 PM
Fire Extinguisher Locations bacampbe Gear & Maintenance 16 06-12-2009 07:44 PM
Re: Fire extinguisher NewsReader Mass Bay Sailors 0 04-09-2007 04:15 PM
Fire extinguisher NewsReader Mass Bay Sailors 1 04-04-2007 02:26 PM
