Old 02-11-2012
minnow1193's Avatar
minnow1193 is on a distinguished road
thru-hulls?
I need to replace/reseal the thru-hulls on my Balboa 20'. Originals are bronze or brass. Saw at the store that there are a couple types of composite/plastic fittings available. Is one better than the other? I know it depends on what is being attached to it. Also, will be painting the bottom at some point, better to install them prior to painting, or after to better seal them from the outside? Thanks in advance for any help.
Old 02-11-2012
mitiempo's Avatar
Bronze not brass. Brass doesn't last long in salt water.
The composite ones are Marelon, much tougher than plastic.
Best to keep the materials alike - all bronze or all Marelon.
Here's are 2 links for installing thru-hulls.
Seacock & Thru-Hull Primer/Pre Information Photo Gallery by Compass Marine at pbase.com
Replacing Thru-Hulls and Seacocks Photo Gallery by Compass Marine at pbase.com
Brian
Old 02-11-2012
MarkSF is on a distinguished road
Groco bronze seacocks are the way to go. They aren't that expensive.
A good yard will paint the outside of the mushroom (including the bore) with anti-fouling paint. So yes, install them before painting, then paint the lot.
Bristol 31.1
Old 02-11-2012
minnow1193's Avatar
Thanks for the help. Paint will adhere to bronze ok?
More than 3 hulls? Ever been done? TintedChrome General Discussion (sailing related) 19 10-09-2010 07:09 PM
16' hulls jackie19 Gear & Maintenance 0 06-24-2010 01:26 PM
pvc in through hulls bar1 Islander 2 03-08-2010 01:20 PM
2.5 hulls planzman Boat Review and Purchase Forum 4 07-18-2008 11:20 AM
GRP hulls radly53 Boat Review and Purchase Forum 4 03-20-2007 04:35 PM
