Like Tree19Likes
  #61
Old 02-27-2012
capttb is on a distinguished road
Might as well be hung for a sheep as a lamb.
  #62
Old 02-27-2012
Capt Len is on a distinguished road
You could be the bastard whose power cord I left on the dock in 12 inch lengths. Granville Island '86?
  #63
Old 02-27-2012
Must be, unless there's another disgruntled Canuck with an axe running loose in the islands. I thought the way all the pieces were exactly 12 inches might display some OCD tendencies but we all got our quirks. I hope it wasn't my midnight rendition of Werewolves of London that pushed you over the edge.
Werewolves Of London - YouTube
AH OOOH!!!
  #64
Old 03-08-2012
wmclibby is on a distinguished road
Re: Honda generator(s) in lieu of running auxiliary
I borrowed a Honda from another sailor to try out and it was not as I expected or anticipated. The sound level was not bearable to us so put that idea to rest. My high output alt and substantial battery banks appears to be our best solution.
  #65
Old 03-08-2012
ODay e-pod's Avatar
ODay e-pod is on a distinguished road
Love my Eu200kc2
  #66
Old 03-09-2012
Tree is on a distinguished road
I don't want to argue with anyone. My experience is different that most of the comments I've read here. Maybe it's because I have a small boat. My battery bank is only 230 amps. I cruise in an area where shore power availability is rare. I bought a
Honda eu1000i a couple of years ago. Wow! I love it! I use a "smart" charger that steps down through several stages of power starting at 20amps. I don't use a lot of power but after a week cruising, I'm starting to draw down the bank. I can top off my battery bank by running my set up for three to four hours. The last hour or so it's charging at less than one amp. I have a Victron battery monitor that helps me know close to the state of charge. I find it best to do the re-charging mid day when sitting on the hook. Never at night or evening. My rule is, if I can see another boat, I don't run the honda. Well, yeah, if you drop the hook early, you might be by yourself! Even though I'm trying hard not to ofend anyone, I don't find the Honda all that loud. It helps if there is a little breeze. I set the generator on the rear (on my lazaret) of my boat and I put a folded up towel under it to absorb vibrations. It's great. I've been out for as long as 16 days and not have to worry about running out of power. My experience only..... yours may vary.
  #67
Old 03-09-2012
stevensuf is on a distinguished road
connect it to your shore power cable then stick it in the dinghy off the transom
You may post attachments
You may edit your posts
How does a Honda Generator work? LakePirate Gear & Maintenance 20 12-04-2012 01:51 PM
Honda Generator not triggering charger boltnbrew Gear & Maintenance 19 03-16-2012 02:19 PM
Help Please Honda 3000, or Yahama gas generator Popeyensweetp Electrical Systems 0 03-21-2009 04:23 PM
Honda Generator Gas Conversion EuphoriaOz Gear & Maintenance 2 02-09-2008 07:20 AM
Honda EU2000i Generator - Life expectancy GeorgeIP350 General Discussion (sailing related) 1 09-11-2006 11:33 PM
SEO by vBSEO 3.6.1
