2 Days Ago
Senior Moment Member
Originally Posted by SebastienL
Thanks for adding the suggestion about powder coating, I didn't knew about this type of finish! A rapid search turned quite a few shops in my area (mostly involved in painting auto and bike parts).
So far, I've only received a quote from one at 200$, including sandblasting and prep. Does that seems like fair price?
Sounds right for this area - just sandblasting one steel wheel cost over $25 twenty years ago. I had some powder coated aluminium parts on my boat that were horribly corroded UNDER the P.C. - apparently the moisture got under it somehow and left the coating practically floating on a layer of "encapsulated" Al2O3.
By the way, if you go that route, get them blasted with walnut shells or plastic media or glass beads, NOT sand - it is very abrasive and aluminium is soft.
"There is nothing, absolutely, nothing half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
