Old 02-13-2012
cousineddy is on a distinguished road
Polyurethane Paint Bottomside?
Im looking for hull paint. It will be drysailed, so I would like something high gloss that could be used topside and bottom side. I want that Jboats, no-waterline look. Polyurethane would be perfect, but its called topside paint. So, what happens if you use that on the bottom?
Old 02-13-2012
tommays's Avatar
Its lifts if you leave it in the water a bit to long
Even shrinkwrap will lift it from the topsides if water gets between it and the wrap
The bottom is normaly epoxy that is rated for underwater
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 02-13-2012
Should I use epoxy paint on just the bottom, or should I paint the topsides too with the same stuff? Any recommendations on the paint brand?
Thanks!!
Old 02-13-2012
Siamese is on a distinguished road
What kind of boat do you have, and what is the current condition of the bottom? Painted, bare?
The epoxy that's used on bottoms is not suited for topsides. It looks like bottom paint.
Paints that are good for topsides, are likely to lift off if you use them below the waterline.
Maybe someone's aware of a gloss paint that'll work below the waterline.
But...help us out with kind of boat and current bottom condition and more ideas will likely be forthcoming.
Old 02-13-2012
Its a US 25. The bottom is half worn off antifouling paint. Im planning to completely sand this off. And didnt wanna put ugly bottom paint back on.
Old 02-13-2012
shogan50 is on a distinguished road
Look at Petit Vivid series bottom paint.
Islander 30 MKII "Sojourn"
Old 02-13-2012
Ill check that stuff out. What about acrylic enamel? Will that work under water?
Old 02-14-2012
tommays's Avatar
Durepox is the stuff BUT i dont want to give you a stroke on the 400+ dollar a gallon price
Tommays
Northport NY
Old 02-14-2012
AllThumbs's Avatar
midlife crisis member
AllThumbs is on a distinguished road
If it's dry sailed almost any topside paint will work. My boat is left in the water. I used garage floor polyurethane on my topsides and boot stripe 4 years ago and it's still perfect. The boot stripe is half in the water all season long. Don't over think it.
Old 02-14-2012
Sweet. What you said is what i was thinking. I just wanted someone else to say it. The longest she would be in the water is a long weekend. Polyurethane is cheap and looks great. So thats what ill do.
Tags
polyurethane underwater
sanding/polishing linear polyurethane paint? Epicurean SailNet FAQ's 1 01-09-2012 02:19 PM
thinning polyurethane paint meboater Gear & Maintenance 2 05-26-2010 10:07 AM
Polyurethane on toe rails? CalypsoP35 Gear & Maintenance 10 05-03-2010 07:32 PM
Epoxy or Polyurethane Maine Sail Gear & Maintenance 6 03-03-2008 02:05 PM
2 part polyurethane paint mikehoyt Gear & Maintenance 1 11-23-2001 07:20 PM
