Propane Outboards? - Page 2 - SailNet Community
 8Likes
post #11 of 37 Old 02-20-2012
Learning the HARD way...
eherlihy's Avatar
If you have a propane powered stove, this means that you have one less fuel to carry with you. Here is what I currently have to carry:
  1. Diesel - in tank
  2. Propane - in locker
  3. Two-stroke Gas/Oil/Stabil mix - in spare propane locker
The Lehr would eliminate the need for #3.
That, and not having to worry about a gummed up carb, makes it appealing to me.
Also, I believe that they run on the 1lb disposable cylinders.
Unfortunately, like any other 4 stroke, they will require periodic oil changes...
eherlihy is online now
post #12 of 37 Old 02-20-2012
tommays's Avatar
Lehr seems to be doing a nice weedwacker for Sears which is pretty inpressive BUT i gotta be a littel bit concerned about who is making the base outboard ?
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #13 of 37 Old 02-20-2012
bljones's Avatar
Originally Posted by acarter92 View Post
Maybe I'm wrong, but a 5hp motor "should be" 5hp whether it's powered by gas or propane. So maybe it's a little bigger displacement than a 5hp gas, but the end result is the same and should have just as much power.
Just my 2 cents
Austin
I thought about that after I posted, but figured somebody smarter then me would correct me. Meanwhile, I am baking bagels and making beef stew. That sorta had (has) my attention.
5 hp is 5 hp. I wonder what the torque is like?
It's 5 o'clock somewhere:
bljones is offline
post #14 of 37 Old 02-20-2012
I saw this on Ship Shape TV. From the demo it looked real nice. Burn equivalent was stated to be 1# propane equal to 1 gallon of gas. Has a connector on the front of the engine to connect larger propane tanks. They said that they produced the entire engine with larger HP's to come soon. Great idea looking forward to how this does in the market place.
CoralReefer is offline
post #15 of 37 Old 02-20-2012
Closet Powerboater
MedSailor's Avatar
My brother had a Ford F-150 that was propane powered. It is actually a pretty easy conversion to a carburated engine. His truck was about as responsive, torquey, and had about as much power as a gas truck. Basically it felt just the same to drive as gas. It also got about the same MPG per gallon of propane as it did as a gas/petrol powered pickup (natural gas conversions get about 1/2 the efficiency per gallon as propane).
I noticed that NOWHERE on their website did they mention the efficiency or estimated usage of propane. How far can we go on a tank anyway???? I emailed the company that very question and will post the response here.
I'm personally quite interested because it would completely eliminate the need to carry around gasoline. I'd much rather only carry 2 fuels than 3. On the other hand, if the efficiency is poor, lugging propane tanks around is a bear and I hear it can be hard to source propane in far off places.
MedSailor
MedSailor is offline
post #16 of 37 Old 02-21-2012
"A 20-pound propane bottle will power the engine for about 50 hours, or roughly the same run time as a conventional outboard and 5-gallon tank. ... Notes Lehr founder and CEO, Capt. Bernardo Herzer, the engines will cost you about half as much to run as a gasoline-powered outboard because propane is less expensive than gas."
Obviously this is technology from Area51, because a "20" pound propane bottle is usually filled to something like 17 pounds now that the "new" safety valves are in them all. And at something like $20 per fill, that would make them dollar for dollar even with a five gallon gasoline fill at $4/gallon, which is marina pricing not road pricing. yet.
Burning cleaner, yes. No degunking, yes. Handy for a lake boat when you've already got two 20# bottles on the deck for your grill. But this is the first time I've heard the fuel densityof propane and gasoline are the same, I'd expect a 20# propane bottle to last only half as long as a five gallon gasoline tank.
jrd22 likes this.
hellosailor is offline
post #17 of 37 Old 02-21-2012
How cool!
I would not hate outboards so much if I could eliminate the gas/petrol related issues. I have been running a trolling motor on my inflatable but the concentrated weight of the battery does not work well and batteries take too long to charge when off the grid.
The idea of running the tender on the 16.4 oz cartridges is great. The 16.4 oz cartridges are refillable - see:
Propane Refill Kit - Refill Propane Bottles with Ease!
If nothing else this gives me an excuse to go to West Marine. Anyone know how long the backorder queue is?
shanedennis is offline
post #18 of 37 Old 02-21-2012
tommays's Avatar
I want to run a 5Hp motor 50 hours on 5 gallons of anything
bubb2 likes this.
Tommays
Northport NY
tommays is offline
post #19 of 37 Old 02-21-2012
Closet Powerboater
MedSailor's Avatar
Do you know if that quote is for the 2.5 or 5HP motor? Also I wonder what throttle they're talking about. Half? Full?
MedSailor
post #20 of 37 Old 02-22-2012
midlife crisis member
AllThumbs's Avatar
Anything that uses the 1 lbs bottles as fuel is NOT environmentally friendly. The bottles are disposable, which means they go in a land fill if you are lucky. Most landfills, at least in Canada, won't take them, and they need to be disposed of at a hazardous waste depot, and they charge to take them, about the same price as they cost to buy.
If you convert an outboard to propane, make sure it uses the refillable bottles if you are concerned about the environment. Refillable bottles come in sizes as small as 5 lbs.
I sail.
AllThumbs is offline
Outboards on 24' PaulinVictoria C & C 8 04-09-2011 09:40 PM
Small outboards brak Gear & Maintenance 8 09-27-2010 07:20 PM
Generaters & outboards RXBOT Gear & Maintenance 11 03-12-2010 12:12 PM
Outboards in winter Ajax_MD Gear & Maintenance 12 12-08-2009 07:33 AM
Small outboards 1973gx Gear & Maintenance 5 01-07-2005 04:28 PM
