Propane Outboards? - Page 4 - SailNet Community
 8Likes
post #31 of 37 Old 02-24-2012
tommays's Avatar
The whole point to me is getting around the problems E-10 fuel causes in limited use motors as the newer 3 star carbs foul if you look at them funny
The outboard itself is clearly not a covereted name brand and is a chinese something as the price is way to low
There is NO service or dealer network YET
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #32 of 37 Old 02-24-2012
Price to low?
Check Defender
2.5hp Tohatsu $833
6hp Tohatsu $1300 +/-
Propane
2.5hp $1000
5hp $1600
Never Forgotten
bubb2 is offline
post #33 of 37 Old 02-24-2012
tommays's Avatar
Bubb
I seen to many off brands come and go and what makes a great weedwacker tends to be and epic fail in a saltwater outboard
Tommays
Northport NY
tommays is offline
post #34 of 37 Old 02-24-2012
casey1999's Avatar
Originally Posted by ovb View Post
It seems like a waste of time to build these things......some of the new 4 strokes are very clean and efficient. a 5 gallon gas tank is cheaper and easier to use that a 5 gallon propane tank...are these engines quieter than gas?....what I think what would be green and cool would be a electric that would use the battery pack like the cordless tools ....battery goes dead swap one out and recharge it...and a solar charger would make it sweet and easy to use....also I am a newbie to sailnet ...this is cool and you folks ROCK.....thanks....
Voila:
Electric Outboard Motors
casey1999 is offline
post #35 of 37 Old 02-24-2012
midlife crisis member
AllThumbs's Avatar
Tohatsu makes Mercury and Evinrude. It's just a different sticker yo.
I sail.
AllThumbs is offline
post #36 of 37 Old 02-24-2012
pdqaltair's Avatar
Originally Posted by AllThumbs View Post
Anything that uses the 1 lbs bottles as fuel is NOT environmentally friendly. The bottles are disposable, which means they go in a land fill if you are lucky. Most landfills, at least in Canada, won't take them, and they need to be disposed of at a hazardous waste depot, and they charge to take them, about the same price as they cost to buy.
If you convert an outboard to propane, make sure it uses the refillable bottles if you are concerned about the environment. Refillable bottles come in sizes as small as 5 lbs.
They come with refillable bottles. They can be run on disposable bottles.
Point well taken.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #37 of 37 Old 03-22-2012
Re: Propane Outboards?
RE: SailNet Community - View Profile: AllThumbs who said "Anything that uses the 1 lbs bottles as fuel is NOT environmentally friendly. The bottles are disposable, which means they go in a land fill if you are lucky. Most landfills, at least in Canada, won't take them, and they need to be disposed of at a hazardous waste depot, and they charge to take them, about the same price as they cost to buy."
I beg to differ, once emptied the 1 pound bottles weigh 14 ounces the same weight of steel and therefore the same environmental footprint of 6 Campbell Soup Cans
You can reduce this impact by refilling the small bottles
Mr. Heater Propane Tank Refill Adapter, Heaters & Accessories, Camp Essentials, Camping : Cabela's
They are easy to empy with a "needle valve tool" when you remove both the fill valve and the overfill valve they are only scrap metal. Our local scrap yards and propane dealers take the empty bottles without charge
Worst case senario, dispose in landfill with same environmental impact as 6 empty cans of Campbell Soup (weight 14oz steel).
wlbutts is offline
Outboards on 24' PaulinVictoria C & C 8 04-09-2011 09:40 PM
Small outboards brak Gear & Maintenance 8 09-27-2010 07:20 PM
Generaters & outboards RXBOT Gear & Maintenance 11 03-12-2010 12:12 PM
Outboards in winter Ajax_MD Gear & Maintenance 12 12-08-2009 07:33 AM
Small outboards 1973gx Gear & Maintenance 5 01-07-2005 04:28 PM
