Old 02-13-2012
VetMike is on a distinguished road
Question Deck mounted versus keel mounted masts
Hello. I'm looking at several boats in the 35 to 40 foot range for Caribbean cruising. I've seen boats with both deck and keel stepped masts and am curious to hear opinions on the merits/deficits of each. Vigor states in his book that one should avoid deck stepped masts and gives a number of reasons.
Old 02-13-2012
davidpm's Avatar
davidpm is on a distinguished road
I think you will find that there is no clear right or wrong way to do it. Keel stepped will let it more water. I think you will find that almost all keel stepped masts leak water into the bilge.
They are tricky to remove and reset with more risk to the interior during the process.
They limit cabin layout options.
They can provide a stub to attach a jury rig after a dis-masting.
It is possible that a failure can cause deck damage that can lead to sinking.
A deck stepped mast can be strong too it just has to be designed properly.
What specifically did vigor say he didn't like, which book?
Old 02-13-2012
Bristol 45.5 - AiniA
killarney_sailor is on a distinguished road
I agree that it is more a matter of sound engineering that anything. I prefer a keel-stepped mast, but that is likely just because I have had several boats that had them and am more comfortable with them - probably someone who had had deck-stepped masts would like them better.
Back in Brisbane. Have paid the entry fee for the Sail Indonesia Rally at the end of July, so I guess we are going to Indonesia and then South Africa. You can check OnAinia.blogspot.com for updates on our travels.
Old 02-13-2012
hereandnow's Avatar
hereandnow is on a distinguished road
As mentioned by davidpm, this is an ongoing debate with both having their pros and cons, along with all the other you decisions you'll need to make when buying a new boat.
I have had both deck and keel stepped with de-masting annually. When I was looking for my current boat deck/keel step mast was lower on the priority list, below speed, comfort, sound structure, ease of sailing, and med - low maintenance.
Whatever way you go I do suggest you make sure the deck around the step is sound with absolutely no moisture or else repairs could be very costly. For the keel step, similar advise if ply it is supporting the step - but repairs may be easier and less costly replacing this with a more solid material, perhaps stainless plate.
Dan
s/v Here and Now
Celestial 48'
Old 02-13-2012
BarryL's Avatar
BarryL is on a distinguished road
I prefer deck stepped
Hello,
I have had both. I prefer deck step. This is because:
  • Deck stepped is drier. I am constantly trying to adjust the boot on my keel stepped mast. It always leaks some water in when it rains and I hate that because I work hard to keep the bilge dry
  • Deck stepped mast is shorter (and cheaper) - my boat gets hauled each year, the rig taken down, and stored during the winter. I pay one price for the boat and another for the mast. A deck stepped mast is longer and that costs more $ (not much but you know how cheap sailors are).
  • Deck stepped is easier to step and unstep. Every spring and fall I worry abut the mast being stepped / unstepped. The mast wires need to get fished around and connected, etc. On my deck stepped boat there were simple plugs that made connecting easy. Also, there are no wedges to play around with.
Just my $02
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 02-14-2012
Thanks! In Vigor's book "The Seaworthy Offshore Sailboat", Chapter Two, point 44; he gives two points to a deck stepped mast which is less offshore worthy than keel stepped but no further explanation that I could find. I'm re-reading the book now to re-find his discussion on this. I do appreciate all the help!
Old 02-14-2012
Rockter will become famous soon enough
Deck-stepped for me.
Easier to lift the mast, methinks.
I have never had a keel-stepped mast.
I should miss that beautiful stainless sampson post dominating the cabin if i did.
As for leaks. My ship has always leaked so it doesn't make any difference, really.
Old 02-14-2012
Jeff_H's Avatar
Super Moderator
I personally strongly prefer a deck-stepped mast over a keel stepped mast but once again this is an area where opinions can differ widely. There is no right answer here. There is a contingent that thinks that the only proper way to step a mast is on the keel. There is a logic to that opinion but it is a logic that can be engineered around and which comes out of a historical context that is less relevant with modern materials and design approaches.
I would like to start this discussion with the structural basics, the base of a mast has a vertical and horizontal thrust to it that tries to push it down through the bottom of the boat and also sideward off of the mast step. In normal conditions the down load is several times greater than the side load. Beyond the loads imparted to the boat, there is also the issue of the loads that happen internally in a mast. When you look at the structure of a mast it is really a truss standing on end but it does not completely act as truss because the components of a truss are not supposed to have bending loads on them. Ideally the loads in the mast are primarily axial (acting along the length of the mast) rather than in bending (acting perpendicular to the long axis of the mast). But because of the continuous attachment of mainsails and the point loadings of intermediate control lines like vangs, pole lifts and the like, masts do have fairly large bending loads imparted into them. The two most often cited reasons for keel stepped masts being considered stronger is the way that the bending loads (moments) are distributed within the mast itself and the way that the mast imparts its loads into the boat.
One of the goals in designing a mast is to create a configuration that, within reason, reduces the size of the bending moments within a mast. In a general sense, the greater the number of panels (segments between shrouds and other supports) the smaller the moments within the mast would tend to be. In the days when single spreader rigs were most common a keel-stepped mast added one extra panel, the segment between the mast partners at the deck and the keel. This has become less significant as bigger boats have routinely gone to multiple spreader rigs (adding more panels above the deck) and to a lesser extent as moment connections at the deck are being employed on deck mounted mast steps.
In terms of the way that the mast imparts its loads into the boat, masts are generally located in the area of the cabin trunk and because of the shape of the cabin (i.e. the deck folds up at the cabin side and horizontal again at the coach roof) this area, if the deck is not engineered for side loads it is more prone to lateral flexing than would be the keel. One idea behind a keel-stepped mast being stronger is that with a keel stepped the mast is not superimposing loads into the deck.
In reality, this ideal is rarely accomplished for a number of reasons. First of all, if the mast is not tied to the deck or the deck tied to the keel near the mast, either with a tie rod or with a tie from the mast to the deck and a connection from the mast to the keel, the downward force of the mast working in opposition to the upward loads of the shrouds can pull the hull together like a bow and arrow lifting the deck and separating the joint between bulkheads and the deck. You sometimes see this type of separated bulkheads on inexpensive or early fiberglass boats with keel stepped masts.
Not only do keel stepped masts impart vertical loads into the deck (through the ties mentioned above) but they also typically end up imparting side loads as well (they must if they are going to reduce the moments in the mast as mentioned above). This added side load when combined with the multiple panels above deck greatly reduces the structural advantages of a keel-stepped mast to next to zero assuming that a deck-stepped mast is properly engineered, and of course that is a big ‘if’!
There are several things that I consider critical to engineering a deck stepped mast properly. Primary is having a properly engineered jack post below the mast to take the vertical loads of the mast. (A jack post is a vertical member that carries the vertical loads of the mast to the keel.) My preference is to have an aluminum jack post rather than a wooden one but a wooden post can work as well. My preference would also be to design the jack post, mast foot and mast step to create a moment connection between the base of the mast and the top of the jack post, so that the jack post could still act as an extra mast panel. Then the deck and interior structure need to be designed to distribute side loads. Ideally, there should be a bulkhead or ring frame adjacent to the mast that can take the side loads and distribute them into the hull. These elements are obviously more complex to engineer and build properly than simply having a fat spot on the keel for the mast step to land on.
My biggest objections to keel stepped masts are to the purely practical. Keel stepped masts with internal halyards mean that there is always water in the bilge. This water comes in at halyard boxes and other openings in the mast and there really is nothing you can do will stop that. Second, it is way harder to step and un-step a keel-stepped mast making the boat more subject to damage in the process. Beyond that if you loose a mast (I have lost two in my life) it is better in my opinion to loose a deck stepped mast because a keel-stepped mast is more likely to damage the deck when it fails and a deck-stepped mast is easier to clear away. The keel stepped mast for offshore use advocates point out that if you lose a keel stepped mast you are more likely to end up with a bigger stump after the mast fails. I am not sure that that is always the case. For example with a deck stepped mast there are cases where you are able to tow the rig as a drogue until things quiet down enough to rig a jury rig. I am not sure what you do when the boat is being beaten to death by the upper portion of a mast that has buckled 20 feet off the deck at the spreaders. .
As mentioned above, my preferred set up is a deck stepped mast that has a welded flange on its bottom that is through bolted through the deck into the top flange of a structural aluminum jack post. If the mast buckles it can be unbolted and jettisoned, or kept up partially by the moment connection at its base. My current boat has a keel stepped mast. It is my intent to pull this mast and have it modified to that arrangement if I ever go offshore with her.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
Old 02-14-2012
casey1999 is on a distinguished road
As others have said, with proper design, either should be fine. There may be some benefits for each, but either, cared for properly should get you around.
As far as Vigor, this boat cirlced the earth 3 times non-stop. Holds the worlds record- and a deck stepped mast:
About Project Endeavour: Refitting the Parry Endeavour
Old 02-14-2012
patrscoe's Avatar
patrscoe is on a distinguished road
Jeff_H,
"my preferred set up is a deck stepped mast that has a welded flange on its bottom that is through bolted through the deck into the top flange of a structural aluminum jack post."
Are you saying that the jack posts has a top flange plate located (height) to the underside of the fiberglass cabin deck and then you have another flange plate with a step for the mast to seat in on the cabin deck, provide a solid spacer within the existing hole where the mast use to go through the cabin deck (not fiberglassing the opening but a solid metal spacer and sandwich the two plates via throughbolt. That's what I am planning to do within the next two years but not sure if that is what you are referring to. I am dealing with a engineer and there is some concern about lateral - horizontal load or movement at the flange and possible reinforcing the fiberglass around this area but I can't see that much movement, while not any more then what you would have with a keel step mast.
Any additional thoughts on this?
Patrick
S2 11.0A
Chesapeake Bay, Va
Tags
mast , mast stepping
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Well Mounted Outboard davidpm Sailboat Design and Construction 28 12-31-2008 01:01 PM
passport 40 - deck mounted mast mightyhorton General Discussion (sailing related) 4 05-28-2007 08:18 PM
Stepping a deck mounted mast while on jack stands DanRudolph General Discussion (sailing related) 22 08-29-2006 03:34 PM
Mast Mounted VHF JebButler Boat Review and Purchase Forum 3 02-28-2005 09:02 AM
