Show me your cockpit table - SailNet Community
post #1 of 6 Old 02-15-2012 Thread Starter
rhr1956's Avatar
My boat has a tiller so there isn't a pedestal for hanging a table on. I'm looking for ideas on making a cockpit table that can be easily stored away or set up for snacks. Got any pictures? Post them please.
rhr1956 is offline
post #2 of 6 Old 02-15-2012
Send a message via Skype™ to Snow Goose
Folding Table
I am looking for a table with drop down leaves. I have searched high & low for something to buy (to suit old boat decor & design) in timber, and have looked for plans to build one, but not having much success. anyone outthere who has any plans or pictures that I can work from? The table will be set uop between bunks when in use.
Snow Goose is offline
post #3 of 6 Old 02-15-2012
I don't have any pics, but try this. It worked on my last boat.
Fold tiller up out of the way.Get table size. Three folding legs under the table, two at the back, one at the front.
the rear folding legs fit into u shaped brackets which are bolted to the rear of the cockpit. so, to put up the table, unfold the rear legs, slide them into the brackets, ( 2 per leg, one high up, and one down low,mounted on the rear cockpit wall).
the front leg( which is mounted under the table in the middle) now unfolds and drops into a hole where the pin in the leg fits.
so, two legs at the back held in the brackets, one leg at the front.
everything folds up and gets stored under the v berth
I hope you get the idea....
Wolf
rg500 is offline
post #4 of 6 Old 02-15-2012 Thread Starter
rhr1956's Avatar
I get a good visual from your decription. My boat has a solid smoked plexiglass companionway door that slides into place. I've been thinking I might be able to use it as a table top. Still thinking...
rhr1956 is offline
post #5 of 6 Old 02-15-2012
maybe a frame that the plexiglass fits into?...
rg500 is offline
post #6 of 6 Old 02-15-2012
I've got an 2-3 in dia. aluminium tube and a deck/table fitting at a marine consignment place that fits the tube. I got poly board at a plastics place. The tube fits into the deck fitting and the table onto that. Works well and didn't cost that much. I've also seen tables hung from the boom.
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is offline
Cockpit table: do it yourself? Plans? geary126 Gear & Maintenance 20 09-16-2014 08:41 AM
DIY Cockpit Table Help? josrulz Gear & Maintenance 23 03-28-2011 09:10 AM
C30 cockpit table jmabe Catalina 2 02-18-2010 01:50 PM
Finishing a Cockpit Table ahalfon Gear & Maintenance 22 07-18-2008 09:14 PM
Lagun Cockpit Table LionFRR Gear & Maintenance 0 09-05-2002 10:58 AM
