Old 02-15-2012
mm2187 is on a distinguished road
Electrical Panel Question
The majority of my electrical system is not fused at all...Older boat. My question is instead of buying all new panels and rewiring can you add something like Blue Sea System Blade Fuse Block after the switch to protect the individual circuits. I am not sure if you get the 12 fuse block if they are individual or all conntected to create a branch effect.
Does anyone have any experience with them
Here is the link to what I am talking about.
ST Blade Independent Sourced Fuse Block With Cover - 6 Circuit - PN 5035 - Blue Sea Systems
Schock - New York 36
Portsmouth, RI
  #2
Old 02-15-2012
eherlihy's Avatar
Will work to sail. :-)
eherlihy will become famous soon enough
That looks like a reasonable solution to your current (ha!) predicament.
Anything is better than what you have now. I would also be concerned about the wire used on your "older boat." Make sure that it is not corroded (green) and stranded at minimum.
gruenlich likes this.
USCG Licensed OUPV Captain, ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
  #3
Old 02-15-2012
AllThumbs's Avatar
midlife crisis member
AllThumbs is on a distinguished road
Looks like the 12 circuit ones all have a common bus. The one you link to is a 6 circuit and it appears that they are individual, without a common bus and without a common ground.
  #4
Old 02-16-2012
mitiempo's Avatar
They are available in 6 or 12 circuits, each either with or without ground bus.
Brian
You may post attachments
You may edit your posts
New electrical panel saillife Electronics 7 07-21-2011 12:15 AM
AC Electrical Panel SVCarolena Electrical Systems 16 03-02-2011 03:59 PM
Electrical Panel bob1956 Irwin 2 09-21-2006 05:38 AM
Electrical Panel whathree General Discussion (sailing related) 2 05-24-2006 10:33 AM
Bypassing the Electrical Panel Don Casey Gear and Maintenance Articles 0 03-15-2001 07:00 PM
SEO by vBSEO 3.6.1
