Rotating Mast Grease - SailNet Community
post #1 of 2 Old 02-16-2012 Thread Starter
I'm looking for advice about what kind of grease to use in the bearing of my rotating mast. The bearing itself is a ball and socket type joint. The base is mounted on the deck and is about the size of a large cantaloup. It has a grease fitting that allows me to inject grease into the bearing while the mast is stepped. The mast itself weighs several hundred pounds and of course the compression on the base is much higher when the rig is fully loaded. My research has turned up a bewildering array of grease types. The only thing that I'm certain about is that its viscosity needs to be greater that lubriplate or standard winch grease. Your suggestions would be appreciated. Thanks
davefromack is offline
post #2 of 2 Old 02-16-2012
Mobilgrease CMS withstands high pressure and is highly water resistant. It is widely used in mining and construction EQ. If it's unavailable locally, you can find it on Amazon.
Hudsonian is offline
windsensor for rotating mast, microPC needed for NMEA correction blubaju Gear & Maintenance 6 03-09-2015 11:28 PM
MacGregor 26M Rotating Mast Seaworthy MacGregor 6 02-03-2014 07:22 AM
Rotating wing masts redstripesailor General Discussion (sailing related) 12 01-04-2011 12:58 PM
Wax And Grease nelsonsmoody Gear & Maintenance 4 02-27-2010 05:00 PM
rotating wing on a cruiser rskaug Seamanship & Navigation 2 03-24-2009 02:21 PM
