Foresail slab reefing - Page 3 - SailNet Community
 7Likes
post #21 of 26 Old 02-17-2012
Senior Moment Member
SloopJonB's Avatar
Originally Posted by bljones View Post
I love the Pardeys for being pioneers, but much of their experimentation occurred 4 decades ago, and much of it didn't work then, all romance aside. If you're not in a hurry to get anywhere, if you want to work harder than you have to and be less comfortable than necessary, then by all means, Pardey Hardy.
Fixed it for you BL.
SloopJonB is offline
post #22 of 26 Old 02-20-2012 Thread Starter
Barquito
Barquito's Avatar
If you decide to go ahead and get a slab-reef in your genoa, don't just let the sailmaker put a horizontal set of reef points at %30 of the sail area. Have him angle the reef in such a way as the new reefed clew, when set, will have a similar but slightly more horizontal angle of the sheet with the SAME CAR POSITION. This will allow you to reef without also having to change your genoa car positions and will simplify the reefing operation significantly. Also the slightly more horizontal pull, in favor of an identical sheet angle to the unreefed state, is better for higher winds.
Good point. If I do this, the sailmaker will be me.
Barquito is offline
post #23 of 26 Old 02-20-2012
Our 150 had reefing cringles. You can see them here:
And Faster's explanation above is perfect for how it all works. However, I never like the sausage. It's probably better if your headsail trims inside your lifelines/shrouds - but it really did get messy tacking with that thing. And keep in mind - I sail in a lake so I do TONS of tacking. Off shore it probably wouldn't matter as much.
All that said, I'm definitely a fan of rollers over hanks.
smackdaddy is offline
post #24 of 26 Old 02-20-2012
bljones's Avatar
I didn't even know Tom made an album... and I'm not gonna mock you too hard for being a fan of the boys in plaid.
No, really. Honest. "Saturday Night" was a rock and roll masterpiece.
(Come on, it was that or question your assertion that you "never like the sausage." I'll take the obscure pop-culture route over easy gay jokes anytime.)
It's 5 o'clock somewhere:
bljones is offline
post #25 of 26 Old 02-20-2012 Thread Starter
Barquito
Barquito's Avatar
I don't think I would switch from roller furling to hanks, if I already had roller furling equipment on board. However, with a number of argument in both columns, I don't see myself switching to roller furling just yet. And yes, I think size does matter. I would want to keep the sausage short enough to stay off the lifelines and inside the shrouds. I'm a lake sailor too, but, could stay on the same tack for a couple of days.
Barquito is offline
post #26 of 26 Old 02-20-2012
Lucky bastard.
Re: Slab Reefing OhioSailor Cruising & Liveaboard Forum 8 08-10-2008 09:54 AM
Single Line Slab Reefing - In Boom jonb Gear & Maintenance 3 04-29-2008 03:58 AM
foresail position? blueranger Learning to Sail 4 07-11-2006 11:48 AM
Multiple foresail furlers Jonathan316 Learning to Sail 4 08-09-2004 01:14 PM
what is slab reefing jbarros Seamanship & Navigation 3 05-30-2003 07:52 AM
