Mast Wear - SailNet Community
post #1 of 7 Old 02-18-2012 Thread Starter
Mast Wear
I am replacing the standing rigging. When I removed the Spreader mounts the holes have become oblong due to wear. The question is, do I drill a larger hole and replace the thru-bolts with a larger size or find some kind of bushing and drill the hole to fit that?
dankel is offline
post #2 of 7 Old 02-18-2012
Find a piece of metal tubing that just fits the bolt and make a sleeve
whorne is offline
post #3 of 7 Old 02-18-2012
or drill out the holes to the next size and use stainless pop rivets,you need a special heavy duty tool to do this
sawingknots is offline
post #4 of 7 Old 02-18-2012
any slack or looseness will just continue to wear very quickly
post #5 of 7 Old 02-18-2012
Lake Superior Sailor's Avatar
Really need more information to your problem , all spreaders are not mounted the same...Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #6 of 7 Old 02-20-2012 Thread Starter
The Spreader mounts are through bolted using 2 bolts 1/2" inch thick. I am leaning towards using the metal tubing.
dankel is offline
post #7 of 7 Old 02-20-2012
I think that is a good choice. Cut the length carefully so that it will fill the holes but not too long or you won't be able to tighten the bolts enough to pull the brackets snug. Good luck
whorne is offline
What to wear in the BVI? BoxedUp General Discussion (sailing related) 19 04-24-2010 03:33 PM
Going to Sea? What watch would you wear? johnnyandjebus General Discussion (sailing related) 57 11-21-2009 05:05 AM
mushroom eye wear coldfoot Gear & Maintenance 8 11-27-2008 09:15 PM
What Lifejacket do you wear ozsailer General Discussion (sailing related) 19 12-14-2007 11:34 PM
What to wear? sailbabe07 herSailNet 11 09-21-2007 10:06 PM
