Extra drive belt on Yanmar 3GM - SailNet Community
post #1 of 2 Old 02-19-2012 Thread Starter
Tomasailing's Avatar
I am looking to fit a belt drive Echotech Watermaker to my Yamnar 3 GM.
Has anyone got any good ideas about mounting?
Space is very limited as it is in a catamaran and access os over the top..
Theere is not much space on the sides?
Tomasailing is offline
post #2 of 2 Old 02-19-2012
LakeSuperiorGeezer's Avatar
You may have to use solar panel and/or heavy duty engine driven alternator and convert to 115 volt AC to drive Echotech if not enough room. Consider http://www.balmar.net/2011-Balmar-Product-Guide.pdf You would probably need 150 amp small frame alternator with dual belts or serpentine. If you want more than 13 gallon/hour, get large frame alternator if it will fit.
LakeSuperiorGeezer is offline
Navico (Simrad) WP 300 CX drive belt replacement f8crusader1 Electronics 4 09-24-2016 09:45 AM
Yanmar 3YM30 Alternator Belt cyphert Gear & Maintenance 13 01-23-2012 09:17 PM
Drive Belt For Autohelm 4000 becky52 Gear & Maintenance 15 07-02-2011 09:09 PM
auto pilot drive belt agoodman Gear & Maintenance 3 07-22-2010 10:18 AM
How to belt drive just about anything from any engine - DIY yachtwork Gear & Maintenance 2 01-24-2010 02:37 PM
