Dive compressor aboard - worth every penny - Page 2 - SailNet Community
 2Likes
post #11 of 26 Old 02-20-2012
Senior Moment Member
SloopJonB's Avatar
No more hydros and visuals, which were happening too frequently and costing ever more.
It's been 36 years since I qualified - can you elucidate that code?
SloopJonB is offline
post #12 of 26 Old 02-20-2012
Originally Posted by Zanshin View Post
.....when I'm at 70 feet and have been down there long enough to need a 3 minute stop at 15 feet.....
That's a long time at 70 ft. Over 45 mins conservatively, even longer if using a dive comuter. Most (not all) could not get a standard tank to last that long at that depth. Although, a 3 min hang means you didn't blow it by much. Not worth the few extra mins below.
On the other hand, you may mean a standard precautionary decomp stop. If one wants to use a hookah, they could always hang a bailout bottle at 15 ft on their down line, in the event of a failure.
Jeanneau 54DS
Minnewaska is offline
post #13 of 26 Old 02-20-2012
neverknow's Avatar
Ok I give up what's a hookah? I did a google search and found a million hits but most all were this???
neverknow is offline
post #14 of 26 Old 02-20-2012
Close. Replace the tobacco with a compressor.
Brownie's Third Lung
Jeanneau 54DS
post #15 of 26 Old 02-20-2012
neverknow's Avatar
Damn I knew it..... But the other might be more fun.
post #16 of 26 Old 02-20-2012
Be aware oillesss compressors can overheat and pump poisonous gasses into the tank. There are no sensor or safety systems available to stop filling a tank if the compressed air is contaminated.
Larger oil lubricated compressors produce hydrocarbons which can be detected and either filtered or the system turns the compressor off.
Maintenance on compressors filling breathing air into tanks is essential to safety.
INMA is offline
post #17 of 26 Old 02-20-2012
SloopJonB's Avatar
tobacco????
post #18 of 26 Old 02-20-2012
The biggest consideration for compressed air is the quality of the intake. If you have to run the genset to run the compressor, you need to be very careful that the genset exhaust isn't being blown over the compressor intake. Blood cells love carbon monoxide, something like 8-1 over oxygen, leaving no room to carry O2. Breath it under pressure and you're toast. A filter isn't good enough for me.
Jeanneau 54DS
post #19 of 26 Old 02-20-2012 Thread Starter
Zanshin's Avatar
Genset running at anchor, intake at front of boat separated by 50 feet - regardless of wind direction the input air is clean, unless one anchors directly upwind of a pollutant.
Zanshin is offline
post #20 of 26 Old 02-21-2012
I don't discuss my member
Fstbttms's Avatar
Think of the time & money you'd save if you could just scrub your bottom regularly instead of hauling & painting.
Regular hull cleaning does not replace anti fouling paint. You still need new paint every 2-3 years. Hull cleaning is simply a normal part of maintaining that paint.
Agree with Zanshin about diving deep with one - I'd stay above 50'. Going to decompression depths sounds too much like old style hard hat diving, the mere concept of which always gave me the creeps and claustrophobia. It also killed a LOT of divers.
Decompression depths begin at 33', not 50'.
Fstbttms is offline
Tags
caribbean , compressor , diving , scuba , zanshin
Dive Compressor Tips rcontrera Gear & Maintenance 2 03-13-2011 12:11 AM
Fwd: Re: Penny, MassBaySailors, a great local Sailing resource NewsReader Mass Bay Sailors 0 07-16-2007 11:15 AM
Beachcat Sailing Series at Fort Worth Boat Club, Fort Worth, TX (The Beachcats) NewsReader News Feeds 0 02-12-2007 03:15 PM
Scuba compressor trecksail Cruising & Liveaboard Forum 2 10-05-2005 03:15 PM
