Which In-hull transducer? - SailNet Community
post #1 of 3 Old 02-22-2012 Thread Starter
71Irwin32's Avatar
Question Which In-hull transducer?
I'm trying to find a good....reliable in-hull transducer with a simple digital display. I don't want to have to turn on my chartplotter to read the depth.
I'm certain some members here experience with these.
Thanks!!!
Ed
71Irwin32 is offline
post #2 of 3 Old 02-22-2012
Courtney the Dancer
jrd22's Avatar
I've had the best luck using an Airmar Smart transducer when in a well. The more powerful the better, they seem to lose some capability shooting through the hull, ours is rated for 100 fathoms but cuts out at 50 (which is just what we need to set our prawn traps). I don't have a recommendation on a display, I ran ours to the Garmin chartplotter. The other one I installed in our last boat we used a Furuno display in the cockpit and it worked well but there must be other displays that are nema 2000. Use a zip lock bag (doubled) with mineral oil in it to "test" the mounting locations prior mounting your well.
link to one example of smart ducer
Depth And Temp Transducer
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #3 of 3 Old 02-22-2012 Thread Starter
71Irwin32's Avatar
Yes, the P79s is the best and will plug into my chartplotter without a sounder. I'm hoping to find one...or figure out whether a p79s or p79 (not smart and $100 less) can be hooked up to a simple digital readout.
Tags
in-hull transducer
Best in hull transducer Waltthesalt Electronics 3 03-25-2011 09:20 PM
Shoot thru hull transducer clarity36 Electronics 5 03-17-2011 10:12 AM
Through-hull transducer? flyingwelshman Gear & Maintenance 5 04-22-2008 11:27 AM
Removing Thru Hull Transducer chuck711 Gear & Maintenance 4 02-13-2007 02:13 PM
Thru Hull Transducer pixurman Gear & Maintenance 2 05-21-2002 07:04 PM
