Adding a proper cunningham - SailNet Community
 1Likes
  • 1 Post By RichH
post #1 of 5 Old 02-22-2012 Thread Starter
Right now the main just has a cunningham line that goes from a cleat on one side of the main, to the other. As it's hard to use, it never gets used!
I would like to bring the line back to the cockpit, and I think I would like to add some blocks at the mast to give some reduction/mechanical advantage. So if you have this, what reduction do you have and, ideally, could you post a pic of the arrangement?
Thanks.
MarkSF is offline
post #2 of 5 Old 02-22-2012
Here's the page out of the Harken catalogue with some examples:
Harken Hardware Catalog
We are using a 3:1... on a former 24 foot race boat we used 6:1 for ease of adjustment.. you can use relatively small line and blocks for this.
Faster is online now
post #3 of 5 Old 02-22-2012
I don't discuss my member
zz4gta's Avatar
I've used a 6:1 on a J24. Should be enough for your bristol. The 6:1 on the 24 was that way for fine tuning, not b/c it needed the purchase. They used Harken micro blocks. You could use the ti-lite blocks, carbos, I'd suggest Garhauer, but they don't make anything small.
You could do a cascade, but might be more trouble than its worth.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #4 of 5 Old 02-22-2012
Remember you're a womble
PaulinVictoria's Avatar
I have a 6:1 arrangement, with some fancy schmancy dyneema type stuff. Can't remember exactly, but it's strong enough to lift the boat up, and plenty to put some significant tension on the luff.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #5 of 5 Old 02-22-2012
RichH's Avatar
I use a direct dyneema line to a 20:1 coachroof mounted winch / Garhauer gang of rope clutches ... on a 440 sq. ft mainsail.
gooseneck fitting ---> cunningham (strap eye on sewn web .. one side of sail's luff reinforcement patch) ---> mast base sheeve ---> deck organizer ---> clutch ---> 20:1 winch.
If your main's headboard is NOT above the 'black mast top band' .....'If the halyard is properly tensioned to remove boltrope 'preload' in a dacron sail (normal preload is ~1" strain per 10-11ft. of luff length) - all to get a proper luff hoist / stretch-out ........ you wont need 'much' cunningham strain *distance* to affect the position of max draft location adjustment in the lower panels. All depends on how well the mast track is lubricated !!!!
If the headboard is AT the black band, then of course youll need all the cunningham 'movement' you can get ... still at about 1" per 10-11 ft. of luff length.
On my sport boat, the cunningham is a sewn cringle: deck cleat ---> mast base block ---> (stainless 'strap' through the cringle with block on each side/end of the 'strap') first block ---> block attached to mast base -----> second block on strap (on opposite side of sail) ---> mast base block (opposite side) ---> deck cleat. Allows setting cunningham from 'either' side of the boat w/ 4:1 purchase
Flybyknight likes this.
RichH is offline
How to setup the cunningham - J24 Drake76 Learning to Sail 3 05-30-2010 10:15 PM
cunningham rgberry53 General Discussion (sailing related) 17 12-20-2009 07:53 PM
Adding a cunningham cringle jaschrumpf Gear & Maintenance 4 04-08-2009 01:54 PM
Adding rigid vang + Cunningham ereuter Gear & Maintenance 5 08-16-2008 08:53 AM
cunningham ? Mike244 General Discussion (sailing related) 19 12-01-2007 11:58 PM
