Cockpit drains not draining... - SailNet Community
post #1 of 12 Old 02-22-2012 Thread Starter
Our sink drains into the cockpit drain thru hull. There are two cockpit drain thru hulls, both are just fiberglass tubes leading to the bottom of the boat with no seacocks. I have no idea if there is some kind of valve in there or what. I stuck a metal rod into both drains and VERY, VERY lightly tapped it. When I tapped it, it was hard. The bottom has some growth and barnacles from sitting for a while, I just bought it. Am I tapping barnacles clogging the drains? Can it be plunged? Any suggestions? The boat is a Pearson 26 and I checked the normal Pearson 26 sites with no luck.
WildJasmine is offline
post #2 of 12 Old 02-22-2012
dive the boat
Clear the blockage from the water. Have two correctly sized plugs standing by and a mallet.
gtod25 is offline
post #3 of 12 Old 02-22-2012
minnow1193's Avatar
I would imagine it IS barnacles etc....I recently bought my boat in St. Pete and it had been sitting in the water for a while. It had an incredibly thick coating of marine life on it. They were up in the swing keel trunk and in all the thru hulls. If no valves, there shouldn't be anything impeding the water flow, so a thin probe will probably be able to knock them loose.
minnow1193 is offline
post #4 of 12 Old 02-23-2012
Sailor
Gladrags1's Avatar
It most likely is barnacles which are best cleared from the bottom. I would take a slim blade such as a paint scraper / putty knife or screw driver and dive under the boat to scrape off the growth. Wear rubber gloves to protect your hands from getting cut by the sharp shells.
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #5 of 12 Old 02-23-2012
celenoglu's Avatar
Injecting some bleach from the bottom can be helpful. This will kill most of the living organisms inside and it will be easier to clean them mechanically after the bleach.
celenoglu is offline
post #6 of 12 Old 02-23-2012
Chastened
Ajax_MD's Avatar
...and T-ing your sink drain into your cockpit drain is a bad idea...
1981 Tartan 33 #168
Ajax_MD is offline
post #7 of 12 Old 02-23-2012
And no sea cocks is even worse.
Flybyknight is offline
post #8 of 12 Old 02-23-2012 Thread Starter
Yeah, not my doing and both are on the list of things to change at the haulout in 2 1/2 months.
Thanks for all of the suggestions, I will try them out and post what worked for me. You guys are awesome.
post #9 of 12 Old 02-23-2012
Since you seem to know you have a bottom-growth problem that's the most likely cause now.. does your sink drain? You mention the cockpit won't drain, but if the blockage is below the sink drain tie-in then the sink won't drain either..
Straight through tubes are not ideal, as mentioned above.. I wonder if that was factory or if someone 'improved' things... One of your first chores on haulout should attend to these, after reading our MaineSail's excellent article on installing proper through hull valves.
Faster is offline
post #10 of 12 Old 02-23-2012 Thread Starter
Yeah, the sink drains but when it does it backs up into the cockpit. When that started I stopped using the sink but I am sure that if I continued using the sink the sink would back up too.
Cockpit drains theartmkr Sailboat Design and Construction 30 07-24-2013 03:49 PM
CAL 25 cockpit not draining sailguy40 Cal 15 06-07-2013 06:46 AM
Proper Cockpit Draining LittleWingCA Gear & Maintenance 11 09-17-2010 07:16 PM
Cockpit drains gg30citation Gear & Maintenance 40 02-28-2008 12:51 AM
Cockpit Drains SimonV Gear & Maintenance 6 04-13-2007 11:40 AM
