Proper Sail Upkeep - SailNet Community
 1Likes
post #1 of 15 Old 02-23-2012 Thread Starter
Proper Sail Upkeep
I am sure this has shown up on here before but I couldn't jind it so here we go. The US 22 I am working came with a set of sails that I consider to be in good condition. They only have a few mildew stains and are still very flexible.
My question is what is the best way to clean them and what is the proper way to store them for long periods (since the boat is out for a restore)?
Should they be folded, rolled or....?
Thanks,
Jason
jcase12 is offline
post #2 of 15 Old 02-24-2012
Tartan 27' owner
CalebD's Avatar
Cleaning: fresh water with no heavy detergents or excessive brushing/rubbing. Allow to dry thoroughly before storing. The milder the cleaner the less material you will take off.
Storing: Fold vs. Rolled?
There will be strong opinions on both sides but normally it takes a bit of both to get a decent sized sail back into it's bag. Rolling does not seem to create the same repetitive creases that can cause damage as folding in the same place every time can.
Tip: Make sure your sails can't be accessed by mice or other rodents. I know this from experience.
Everybody has one:
CalebD is offline
post #3 of 15 Old 02-24-2012
Every few seasons, we send them out to be cleaned by a company that has a vacuum washing machine that gets everything out. Much better than you'll ever do by hand. In New England, they pick up and deliver and will just keep them for the winter. In the other seasons, I flake and fold.
Jeanneau 54DS
Minnewaska is offline
post #4 of 15 Old 02-24-2012
jimrafford's Avatar
practical sailor has articles on cleaning. I've used it on the last 2 boats. Works great. The sails will look like new. Get a piece of shrink wrap to lay out the sails on.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
post #5 of 15 Old 02-24-2012
We send them to sail care for cleaning they do great work. As for storage we fold and roll our sails up. Like said before store them were mice and water wont get them.
lilslippery is offline
post #6 of 15 Old 02-24-2012
RichH's Avatar
If the sails are woven (white) dacron, they are very easy to clean.
This is a 2 step method that requires thorough rinsing with water between the two steps and a thorough rinsing after the final step.
1. Sodium Silicate based detergent sprayed on, misted with water to totally wet out the sail, brushed out with a long handled 'soft' bristle brush, then covered with a plastic tarp to allow sufficient soak time and to prevent the detergent/water mix from drying out. Then followed by scrubbing (both sides) and covered with plastic tarp, etc. TriSodiumPhosphate TSP can be used as a substitute for the Sodium Silicate based detergent. WM can special order the Sodium Silicate det. (expensive) - it will also 'emulsify' oils, greases, etc. SOAK TIME is important for detergents, soaps, etc to emulsify the dirt ... dont rush the soak time and keep it covered with plastic to prevent 'drying'.
2. Thoroughly RINSE until ALL detergent and dirt, emulsified oils, etc. are extracted.
3. Bleaching Step .... removes iron and tannin staining ('yellows')
Go to hardware or paint store and get a pint 'tub' of oxalic acid crystals - sold as 'wood bleach'. Put 3/4 of a pint of oxalic crystals in bucket and add 'just enough' HOT water to dissolve 'almost all' crystals. Use rinsed long handled scrubbing brush to apply the oxalic mixture to the sail material. This will usually instantly bleach out all the remaining iron and tannin stains. Note- wear protection when using oxalic acid as it rapidly absorbs through the skin and reforms as sharp crystal in the nephrons of your kidneys. Rinse thoroughly with water to extract oxalic acid.
Note: if you live in an eco-whacko state you will not find oxalic acid and will have to 'import/smuggle' it ... oxalic acid is a naturally occurring chemical found in fruits/vegetables (rhubarb, etc.) but the eco-whackos are terrified of anything that can be possibly considered a 'chemical'.
4. Hang or raise sail to thoroughly dry.
Notes:
Woven Dacron Polyester is chemically resistant/compatible with the above Sod.Silicates, TSP, and oxalic acid. DO NOT use 'organic or petroleum based' solvents (gasoline, kerosene, etc.) on polyester.
Woven Dacron Polyester is a 'dirt magnet' ... so be careful not to drag it over dirty, muddy, etc. surfaces when cleaning as if you do you may not be able to extract such 'soil', especially dirt that contains 'carbon'.
Its usually 'best' to clean sails ON the boat: On a cloudy, windless, high humidity day ....Clean the deck first, then slowly raise and lower the sail in 3-4ft. increments as you clean,rinse,bleach, rinse, rinse, dry out. Dont do this ON the boat if you have unprotected teak as the process will extract the tannins from the teak or other bare wood.
DO NOT mix caustic detergents with oxalic acid ... MUST be rinsed thoroughly between the two steps.
Storage - best is to ROLL the sail ... leaves no creases as what happens when 'accordian folding'. Folding will crease the material and over time will weaken any added 'plasticizer -filler' used to 'fill-in' the sails 'porosity'.
hope this helps.
RichH is offline
post #7 of 15 Old 02-24-2012 Thread Starter
Thanks for all the great info guys!!!
jcase12 is offline
post #8 of 15 Old 02-25-2012
TQA
Bombay Explorer 44
TQA's Avatar
Thanks,
Jason
Flexible is not normally considered good. The newer the sail the stiffer it will be! Most [but not all] sailcloths are impregnated with resins which break down over time and use allowing the cloth to stretch. and the sails to get " baggy".
TQA is offline
post #9 of 15 Old 02-25-2012 Thread Starter
I shouldn't have said flexible. I just meant that the material is not dried out and crackly.
jcase12 is offline
post #10 of 15 Old 01-25-2013
Re: Proper Sail Upkeep
CalebD, you mention mice. Do you hang the sailbags from the ceiling, or what do you do to keep the mice away?
growser is offline
proper Sail use MiVelero Seamanship & Navigation 11 12-05-2009 08:58 AM
Inflatable plywood upkeep.. TommyD Gear & Maintenance 3 11-24-2009 08:31 AM
Proper way to fold a sail Stryker72 Learning to Sail 11 12-20-2007 09:36 PM
Proper Sail Number katytoo General Discussion (sailing related) 2 06-02-2007 04:22 PM
Proper Sail Storage SailNet Gear and Maintenance Articles 0 09-17-2002 08:00 PM
