FWIW DIY MOB Pole... - SailNet Community
 2Likes
post #1 of 17 Old 02-24-2012 Thread Starter
Superior Sailor
Squidd's Avatar
First a disclaimer..."This in NOT a IYRU and Transpac YC approved device, but never was intended for Ocean Racing type conditions...Doubt it would be of much use in 10'-15' waves and 30-40 knot winds...and has no strobe or EPIRB attached"...
I built it as a safety /locating device for daysailing and weekend crusing the Great Lakes It's a 26' boat so much over 4'-6' waves the wife will have me heading for shelter anyway...
Made it out of a 6' fiberglass rod ($3 Hdwr store) and a "Nerf like" foam football for flotation ($2 at dollar store) a chunk of lead for ballast (about a lb/free) and a chunk of vinyl flag for visibilty ($1 dollar store) so for about $6 I have a lightweight MOB pole.
Plan is to store on boat rail and deploy with Life Ring with about a 6' rope tied to pole to keep them together, so MOB can locate ring and Boat can locate MOB...
Seems to float well, a little high actually, so I'm going to add another lb of lead to help stability..."football" was in the water for a good 10 minutes and showed NO signs of water ingress, but I'll be putting a coat of clear sealer over it for added protection...
Football was attached to pole and ends sealed with 4200 adhesive/sealant, and then rubber gromets were slipped on and secured with small section of heat shrink tube...shouldn't slide up the pole...
Again not "IYRU and Transpac YC approved" but adaquate for the conditions it will be exposed to...Looking at the approved versions, they are 10'-14' long..!! (that's where they get the stability) http://www.defender.com/category.jsp...3330&id=320542 But on a 26' boat may be a bit of overkill for storage and deployment...
Thanks for looking...
jrd22 and Tafa like this.
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #2 of 17 Old 02-24-2012
Lake Superior Sailor's Avatar
Looks good, hope you never need it!..Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 17 Old 02-24-2012
Barquito
Barquito's Avatar
How did you attach the lead? I was thinking about making a mooring pick-up stick like that. (BTW, I seriously considered naming my boat 'Parsimony')
Barquito is offline
post #4 of 17 Old 02-24-2012
That's great work. I was thinking of doing something like that myself - I need something to practice MOB with.
Think I'll copy your design if you don't mind!
MarkSF is offline
post #5 of 17 Old 02-24-2012 Thread Starter
Superior Sailor
Squidd's Avatar
Lead was drilled for diameter of pole, pole inserted and cross drilled for 1/8" roll pin...
"Captin Ron"
Squidd is offline
post #6 of 17 Old 02-24-2012
Barquito
Barquito's Avatar
You should post this in the 'Low Buck Projects' thread.
Barquito is offline
post #7 of 17 Old 02-24-2012
Works for me, Squidd. My last one was of bamboo, locally grown. Couldn't FIND a find a fiberglass rod, and the bamboo was over 8' long after we trimmed it down. (Height counts, if you're in the trough and need the flag about the wave tops.)
hellosailor is offline
post #8 of 17 Old 02-24-2012
I don't really like the idea of handling lead, OR dipping it in the bay, but it does strike me that I have a nice new zinc for the end of the prop shaft, in a drawer, that's pretty heavy AND has a hole drilled through it already.
MarkSF is offline
post #9 of 17 Old 02-24-2012
Two uses for everything!
It can be used as a MOB pole and a place to store your spare zincs! Awesome!
Seriously though it crossed my mind while reading this that zincs might work as well as lead.
I have been thinking about making one of these poles too and now have a few more ideas to try. I have seen them made with pvc pipe as well.
Regards,
Tanya
tjvanginkel is offline
post #10 of 17 Old 02-24-2012
Thanks for sharing
This is really neat
Tafa
Tafa is offline
Using spinnaker pole to pole out jib when sailing downwind... sweetdreamyamaha Seamanship & Navigation 5 09-08-2010 11:39 AM
Using a spinnaker pole instead of a whisker pole aphil138 Gear & Maintenance 14 03-31-2008 03:51 PM
Wanted a Whisker Pole and a Spinnaker Pole matthiesen Gear & Maintenance 0 02-22-2008 03:10 PM
North Pole. Pete Goss puts Playing for Success Charity in Pole position @ BYM Sailing News NewsReader News Feeds 0 04-20-2006 05:15 AM
