2.5hp outboard engines: The best? - SailNet Community
 1Likes
post #1 of 31 Old 02-25-2012 Thread Starter
I need to buy a small 4 stroke outboard engine and I want your advice about it.
I used for many years a Tohatsu small 2 stroke engine that had give me full satisfaction and never give a problem, but now we have to use 4st engines and that one is out of question.
4st engines are a lot heavier and that rules out anything except the smaller ones, with a weight between 15 and 19kg.
I have tried the Honda and I did not like it: Makes an infernal noise.
Have heard that the small Yamaha has sometimes trouble in starting.
Heard good things about the Suzuki.
and nothing about the Tohatsu, Selva, or about the several Chinese inexpensive one.
Low weight, easy start, low noise and of course trouble free are the main requirements for me and I guess for everyone, not to mention price, of course.
So, who was information to share?
post #2 of 31 Old 02-25-2012
T37Chef's Avatar
For an engine that small, what about a torqeedo electric outboard? They are expensive but not having to carry fuel would be a big plus in my book. For long term cruising they may not be the best answer, but weekends they would be ideal.
torqeedo: Produktübersicht
I used to own the Honda 2 hp, being only air cooled it was loud, and I found it very sensitive to fuel, cold, anything but perfect conditions, hated the thing
Shawn
T37Chef is offline
post #3 of 31 Old 02-25-2012
I have had a Honda 2HP for over 20 years. Still runs perfectly after being run hard for that time. Don't know how to compare the noise issue but it has never bothered me. Has a lot of thrust, driving a 12 foot Jon boat with two people and fishing gear at 5.4 mph per the GPS, weighs 27 lbs and uses almost one pint of gas for about four hours of trolling. Based on my experience I would buy another one.
Paul T
Forgot this, we are at 6,700 feet elevation so it is down somewhat on power compared to sea level.
dabnis is offline
post #4 of 31 Old 02-25-2012
MikeOReilly's Avatar
I'm on the same search PCP, and have pretty much decided on a new 3.5 hp Tohatsu. I've decided against the Honda 2 hp b/c of the noise. It looks great, but it is air cooled, hence the noise.
I seriously considered the Torqeedo Travel. Love the idea of no gasoline, and the aesthetics of low noise and renewal power seems great. But the limited range, and very high cost (could by two or three new gas engines for the same price) has led me back to the Tohatsu 3.5.
MikeOReilly is offline
post #5 of 31 Old 02-25-2012
Courtney the Dancer
jrd22's Avatar
I bought a new Yamaha 4hp which is very similar to the smaller hp models (single cylinder). Hated it for several reasons (loud, hard start, finicky). Sold it at a loss just to get rid of it and bought a used two stroke. Love it. Sorry I can't offer a good suggestion PCP, maybe they have been improved in the last two years, hope so.
Edit: I have a friend that bought a new Torqeedo, he's had trouble with it, not sure exactly what all the problems have been but we could only get it to work intermittently the one time I was out with him on his Hobie and it was less than a year old. Replacement batteries are REALLY expensive I guess.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #6 of 31 Old 02-25-2012
LakeSuperiorGeezer's Avatar
On the Honda, wear ear plugs. Corrosion inside the engine is not a problem with air cooling, although I have to admit that the stainless steels they use in some of the modern outboards is an improvement
LakeSuperiorGeezer is offline
post #7 of 31 Old 02-25-2012
Leocat66's Avatar
Am I to understand that you are not allowed to use the 2 stroke motors any longer or that you just do not wish to do so? We still have a 2.5 merc, 2 stroke, which has been just perfect on our 6'8" Montgomery dink. Weight is the main consideration for us.
Evinrude has the small E-Tec engines which are 2 stroke but EPA approved as related to emissions issues. They seem to be lighter than the 4 stroke engines. My neighbor has a larger E-Tec and loves it. It is now 5 years old and has had no issues.
William Atkin Cutter, "TALLY HO MAJOR" "ROSA"
Leocat66 is offline
post #8 of 31 Old 02-25-2012
JimsCAL's Avatar
Love my Yamaha 2hp 2-stroke. Light (22 lbs) and reliable.
JimsCAL is offline
post #9 of 31 Old 02-25-2012
2.5hp outboards..here's a gamechanger....
here's something very new, a propane-powered outboard:
Propane powered Outboard Marine Engine, 2.5HP, Short Shaft (Lehr) - Four-Stroke Outboards
i have no connection to west marine or the makers of this motor but it sounds interesting.
reviews i've read said it always starts on the first pull, no priming or choking involved, no gas to get stale or gum up the carb.
i have the Honda 2hp and live with the noise. what i don't like about the Honda is not having neutral. the centrifugal clutch is nice but is not an honest neutral until the motor has warmed up.
john madill is offline
post #10 of 31 Old 02-25-2012
Siamese's Avatar
I've used my new Suzuki 2.5 for one season. I like it. I had no problems with it, but I have only one season as a reference.
Pro:
Good runnablilty
Plenty of power for moving my 7' inflatable
nice controls
easy to service (change oil)
lightweight..easy to move from sternrail to dinghy in water
Con:
The noise...seemed pleasant enough at first, like my old Honda Trail 90 from 1966. A quieter two cylinder four stroke engine would be awesome, but likely too expensive. In this power range, you just have to deal with the racket and vibration. I should add that the Suzuki is no noisier than its competition.
I can certainly recommend the Suzuki 2.5, based on my experience.
The main downside to these small motors, IMO, is their vulnerability to stale gas. Carbs with tiny jets that tend to get clogged up. The shelf life of modern gasoline is not long, maybe 4 to 6 weeks before it begins to go bad. More, but not indefinite if you use fuel stabilizer. That's a problem for most of who don't use our little outboards all the time. I try to avoid problems by putting a little stabilizer in the outboard's tank when I'm done using it for a couple weeks or more and letting the engine run until the carb is empty. I pour leftover fuel from my two gallon red jerry can into my car. Next time I plan to cruise and use the 2.5, I get fresh fuel for it. With these little engines, it's ALL about the fuel.
Jeff_P likes this.
Siamese is offline
Outboard Motor Bracket "not for use with 4 stroke engines" petertribo Gear & Maintenance 13 12-02-2014 11:55 AM
Who knows about diesel outboard engines? Exiles Gear & Maintenance 12 01-25-2011 09:55 AM
Beginner's guide to outboard engines? silverbranch Gear & Maintenance 5 06-01-2009 06:45 PM
Gas Engines? Classic30 Gear & Maintenance 24 08-06-2008 02:47 AM
engines warwicksail Gear & Maintenance 6 12-14-2007 09:52 AM
