Re-greasing your Max-Prop - SailNet Community
post #1 of 10 Old 02-27-2012 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
Anyone have any experience with regreasing a Max-prop? The Manual talks about removing 2 setscrews on the spinner. Are these them? I found the Zerc Tower at PYI website. Any other tips to successfully lube my prop?
brokesailor is offline
post #2 of 10 Old 02-27-2012
Sailboat Reboot
svzephyr44's Avatar
Send a message via Skype™ to svzephyr44
I disassemble the entire thing each time I haul the boat to lubricate the moving parts. Make sure you mark the settings so that you put it back together with the proper pitch. I am not sure how just taking the prop off the shaft would give you enough access to lubricate all of the moving parts.
svzephyr44 is offline
post #3 of 10 Old 02-27-2012
Looks like them from here. Pull the set screws, one at a time, and replace it with the zerk fitting. One pump of grease from the gun and then fully rotate the prop in both directions. Then another pump and fully rotate again. The moment you see any sign of grease, stop and rotate several times. It will appear under the blades from one fitting and from the seem with the other. Do not over fill with grease, as that will make it harder to feather. The blades should turn easily.
Use the right waterproof grease. I bought it from PYI themselves, but I'm sure it isn't proprietary and I don't have it nearby to tell you what it is.
Jeanneau 54DS
Minnewaska is offline
post #4 of 10 Old 02-27-2012
p.s. I don't think it's really necessary to fully disassemble each year. However, if you do, be sure to replace the cotter pins, don't reuse them. There are good vids on YouTube (published by PYI) to show you how to do it.
When you replace the zinc, be sure to clean the contact area well. Its often corroded and you need good contact for the anode to work properly.
Jeanneau 54DS
post #5 of 10 Old 02-27-2012
Lubriplate 130 AA is what they recommend...
Edited.. checked the PYI pdf....thanks jsaronson
http://www.pyiinc.com/index.php?sect...tallation&sn=3
Faster is offline
post #6 of 10 Old 02-27-2012
jsaronson's Avatar
Actually, its Lubriplate 130 AA. don't know what the difference is ...
jsaronson is offline
post #7 of 10 Old 02-27-2012
billyruffn's Avatar
Just a thought: After I noticed that water came out of the prop when I greased it, I started doing it in the fall as part of the winterization process to purge the seawater and reduce the possibility of internal corrosion over the long winter.
billyruffn is offline
post #8 of 10 Old 02-27-2012
I suppose that's a good point to prevent freezing damage too. However, I think they may actually recommend bi-annual lubrication and I've never heard of anyone having freeze damage.
Jeanneau 54DS
post #9 of 10 Old 02-27-2012 Thread Starter
SV Skalliwag #141
Thanks Billy and Minewaska.
post #10 of 10 Old 02-27-2012
jsaronson's Avatar
PYI sells the kits:
PYI Inc. Max-Prop PSS Shaft Seal Seaview Radar Mounts R&D
Note, there is a second kit for pre-1991 props that have not been fitted with the grease fittings.
Greasing Hand basin Manual hand pump Frozensurfer Gear & Maintenance 1 05-04-2010 01:53 PM
Greasing Tapered Valve Thru Hulls In the Water ebrda72 Gear & Maintenance 0 12-05-2009 06:17 PM
Greasing Seacocks sachemgfp Gear & Maintenance 1 09-30-2009 11:18 PM
Greasing a Lofrans Windlass Bene505 Gear & Maintenance 0 09-24-2009 01:18 AM
Greasing Outboard bobendaxi Gear & Maintenance 2 04-06-2005 11:35 AM
