Arco 30 Winch Maintenance Question - SailNet Community
post #1 of 11 Old 02-27-2012 Thread Starter
H2814D's Avatar
Hi all. I am trying to re-build/clean an older (I think) Arco 30 USA (that's what it says on the top plate) and am finding I can go no further than removing the top circlip, sliding the bell off (I think that's what you call it), and then I can remove the top two pawls and springs.
I've looked at videos of other models of winches, but can not find one or any information for this particular model. My problem is I cannot get the bearings off, nor can I get to the bottom gears, which look incredibly gummed up with grease. It appears the part that holds the upper pawls has a small lip which prevents the bearings from sliding up and off the main post. I can also see a small hole in this part, but cannot tell if maybe an allen wrench or something is supposed to be used there.
The bottom gear has a pin, but it looks like this pin is pressed into the metal and does not look like it is removable unless it is pressed back out.
Does anyone have experience with this model? Am I going to have to remove the winch from the boat, and if so, will removing the screws mean I have to watch for the nuts falling somewhere?
New to this boat (Islander Bahama 30) and to sailing a larger sailboat (have owned a Hobie 16 forever), so thanks in advance for your replies.
H2814D is offline
post #2 of 11 Old 02-27-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
If you contact them they will email you an exploded diagram of your winch. You'll need to let them know if it is standrad or self tailing, one or two spee.
HUTTON-ARCO Yacht Winches
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #3 of 11 Old 03-13-2012 Thread Starter
H2814D's Avatar
Re: Arco 30 Winch Maintenance Question
Thank you TDW. I e-mailed and very quickly received a response with schematic diagrams of the two most probable winch set ups. It looks like I need to completely remove the winches from the boat to do a proper cleaning/re-lubing. Another boat project...wooohoooo!
H2814D is offline
post #4 of 11 Old 06-04-2012 Thread Starter
H2814D's Avatar
OK so I removed the winches, completely took them apart, cleaned and lubed them, and eventually replaced them back on the boat. They were pretty gummed up. Pictures of the internal parts, and the four of them all back together, after being shined up a bit.
H2814D is offline
post #5 of 11 Old 06-04-2012
I also had this same problem with a used Lewmar winch, and got a schematic from Lewmar (they sent one for a different winch), but I never figured out how to remove the pin and gear. I'm hoping yours will give me a clue to how mine is put together. How did you remove yours?
Sailormon6 is online now
post #6 of 11 Old 06-04-2012 Thread Starter
H2814D's Avatar
Sailormon, the pin is standing upright next to the almost clear plastic ring and the black ring almost directly in the center of the photo. It is pressed in from the top of the main part of the winch base (the brass part in the lower left corner). I had to strike it from the bottom of the base up (I think it was the bottom anyway...I don't remember now). It wasn't too difficult to get it to come out, but you do have to remove the winch base from the boat to get to the bottom of the base.
I used a 1/4" socket extension and a hammer. Just keep carefully hitting it and it should come out. You will have to press or hammer it back in during re-assembly. Just make sure there are no other parts holding the pin in, like a circlip or something, which would probably be visible on the bottom of the base if there was one. There is nothing on the ARCO's, but the Lewmar's may be different.
I used carburetor cleaner on all the metal parts, but not the plastic. Someone suggested mineral spirits, but that took too long to disolve the grease. I did use the mineral spirits on the plastic parts.
I see you are a senior member, so I don't want to insult you, but absolutely no grease on or near the pawls or springs. It gums up their movement and these things need to only be oiled with a light oil for proper operation. The larger gears and the bearings get the grease.
Hope this helps.
H2814D is offline
post #7 of 11 Old 06-04-2012
tdw
tdw's Avatar
Well that worked out well. good to see.
― Terry Pratchett.
tdw is offline
post #8 of 11 Old 06-05-2012
Thanks HD2814D. I'm installing the winches now, but will try tapping them with a hammer the next time I clean and lube them, probably next year. Since I couldn't get them completely disassembled this time, I got them mostly apart and soaked the rest overnight in a solvent, agitating them and rotating the gears frequently, and think I got them fairly clean. I greased the gears lightly and oiled the pawls, and they seem to be working great, so, rather than take them apart again and obsessing over them, I'm going to put her back together and go sailing!
post #9 of 11 Old 06-05-2012
Senior Moment Member
SloopJonB's Avatar
On all the winches I have serviced that had pins like that, they were a slip fit. If you have to use a hammer and drift to get them out they probably have crud on them. Polish them with 600 or 800 wet/dry paper and some WD40 or even diesel and also polish the holes they ride in. It's a good idea to do this to the main bearing races in the drum as well - just polish the varnish off (if there is any of course).
If you use white lithium grease on your winches you CAN grease your pawls & springs with a LIGHT coat. It clings better than oil and won't cause the stiction that is the reason for the "oil only" conventional wisdom.
SloopJonB is offline
post #10 of 11 Old 06-06-2012 Thread Starter
H2814D's Avatar
SloopJon, the pin we are speaking about is definitely pressed in and designed to fit tightly once seated. This winch was probably built in the late 70's. If you look back up at the pictures the pin is standing upright in the center of the picture. It has, although not completely visible there, vertical grooves around the top of the pin that create the friction to hold it in place. It has to be pressed (or hammered) into the mast base through the hole (you can see it in the 6 oclock portion of the base) and the gear to hold it in place, otherwise, it may rise up and contact the lower portion of the bell (?). It certainly wasn't being held because of varnish or the like. It had to be forced out. And I cleaned the heck out of every piece there before I put it back together, and there was nothing going to "slip fit" back in regarding this pin. :-)
I just hope the next time I have to clean winches they will be a bit newer and easier to take apart. Having to completely remove them was a two man job, just to do that and then put them back in.
H2814D is offline
parts for arco winch ivanam Gear & Maintenance 3 05-21-2012 05:06 PM
Arco 6 Winch Help dapperpoet C22 7 11-11-2011 09:26 PM
Barient-20 ST Winch question and maintenance.. TintedChrome Gear & Maintenance 6 11-30-2010 11:29 AM
ARCO Winch Company ABullard Gear & Maintenance 10 03-24-2010 05:35 PM
Barlow Winch Bearing - Hutton/ARCO never responds! belanich Gear & Maintenance 6 05-16-2007 05:07 AM
