Steering System Identity - SailNet Community
 1Likes
  • 1 Post By deniseO30
post #1 of 9 Old 02-28-2012 Thread Starter
Wondering if anyone can assist in identifying (Manufacturer/Model) the Gear and Cable Steering System pulled from a 1969 Cheoy Lee Clipper 36. I could not find any identifying marks or labels on any of the parts.
Many thanks
FineKetch is offline
post #2 of 9 Old 02-28-2012
That mechanism is rather unusual.. not the chain/cable/sprocket that is typical of many of the 'standard' cable steering setups. Also the wheel lock is quite distinctive, hopefully somebody will recognize it.
Are you planning to re-use it?
Except for the cable/quadrant portion below decks the mechanism (pinion gear drive) is similar to our newish Edson link-and-lever steering gear.
Faster is offline
post #3 of 9 Old 02-28-2012
RichH's Avatar
Look for small stampings into the metal parts: "GD"
Looks suspiciously like 'Grand Deer' - a notorious Taiwanese 'knock off' marine supplier. If it is most the of the threaded components will be Whitworth Imperial *Variant* thread profiles or a mix of Whitworth Imperial and Metric (depending on the age).
Note: When checking, Imperial will not mate perfectly with Standard Whitworth but Std. Whitworth will mate with Imperial.
RichH is offline
post #4 of 9 Old 02-28-2012 Thread Starter
RichH
Many thanks for taking a minute to respond and for your parts mating advice. I'll likely start the tear-down this weekend.
Mark
post #5 of 9 Old 02-28-2012 Thread Starter
To Faster
Thank you also for responding to my query. I'm beginning the process of tearing down and refurbishing.
FK
post #6 of 9 Old 02-28-2012
One of None
deniseO30's Avatar
the steering gear or the boat? If it's the boat we want photos! we love armchair restorations!
SloopJonB likes this.
My last project!
deniseO30 is offline
post #7 of 9 Old 03-11-2014
Re: Steering System Identity
Glad to see your post!
I'm having trouble finding info on my cheoy lee luders 36 steering system, it's the same as the one in your picture. I'm going to attempt to replace the cable next week - the tension is not good and I can hear it slipping when I turn the wheel hard in either direction. I'm wondering if you have any advice on how to replace and tension the cable - I'd prefer to do that rather than replace the whole system.
Jessiealsop is offline
post #8 of 9 Old 03-11-2014 Thread Starter
Thanks for writing. I finally discovered through numerous other research contacts that the pedestal and steering gear under the cockpit are likely manufactured by Cheoy Lee and not commercially available units.
Unfortunately, I never was able to come up with documentation. I've taken photos of the setup before I tore it down, and I'll be reinstalling and adjusting through "dead reckoning" or working with it until it seems to be correct.
post #9 of 9 Old 03-11-2014
Bristol 45.5 - AiniA
I don't know the Cheoy Lee system but I suspect it will be similar to others. If you look at both ends of each cable you should be able to see how it connects. With the ones I have done, you disconnect the cable where it connects at the rudder end - this is also where you tighten the cable. This may be all you need to do unless the cable itself is starting to fray. To check for this, run a soft cloth over the cable (not your hand unless you want to bleed) and see if it catches. Look in particular where the cable might touch anything, sheaves or anything else because this is where wear happens most.
If you have to change the cable, you loosen it at the rudder, then remove it at both ends and then buy the bits to replace the cable, and likely the clamps that have been used. Not hard to do, but can be awkward to get at on many boats.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
Build Your Own Steering System type2drvr50 Gear & Maintenance 13 10-07-2011 08:21 AM
Recommended oil to lube steering system alex909 Gear & Maintenance 2 06-06-2010 06:07 AM
Steering System Spring Checkup Tom Wood Gear and Maintenance Articles 0 04-26-2004 08:00 PM
Catalina 470 steering system seanote55 Gear & Maintenance 0 08-20-2001 03:05 PM
